help clutch problems
this has never happened to me before,as i driving home my clutch kept going down deeper to the floor to the point where i had to pull over....after doing so i noticed that my clutch fluid was too full so i took some out and it drove fine but it happened to me once again before i got home but what could this problem be??? after it happened one more time it drive fine for the rest of the ride home...
is this a serious problem ?
can i still drive the car safey?
what is causing this?
please inform me if u know whats going on
No it needs to be addressed immediately
You either have a bad clutch master cylinder AND/OR slave cylinder. Check to see which one it is leaking from and replace appropriately then bleed the system...
SloCivicHMM
May 12, 2003 01:57 PM
