Idle at 3-4000rpm, WTF and no codes.. Please Help..
Old Aug 7, 2002 | 10:04 PM
QWKPHKR's Avatar
Default Idle at 3-4000rpm, WTF and no codes.. Please Help..
(B16a1 in a 1990 CRX Si)
Hey guys, my idle is at around 3-4000 rpm and does not go down at all, even when it's warmed up. I changed 3 IAC's, tried 3 ecu's, ran new wires for the IAC, from the ECU and a power supply, checked all vacumm lines and I still have the same problem... Can someone please give me some ideas... I have no idea where I'm gettin this high idle from..
Thanx,
Pete
Old Aug 7, 2002 | 10:13 PM
89 CRX SI's Avatar
Default Re: Idle at 3-4000rpm, WTF and no codes.. Please Help.. (QWKPHKR)
throttle body gsaket and intake manifold gasket. they have to be new and tourqed correctly.........
Old Aug 7, 2002 | 10:15 PM
Aphrodavid's Avatar
just a guess but it could be related to the throttle body or the accelerator cable. try disconnecting it from the TB and see what happens. also, just because it doesnt throw any codes doesnt mean theres not a problem. you may want to check all the sensors for voltage and such.
Old Aug 8, 2002 | 03:32 AM
QWKPHKR's Avatar
Default Re: Idle at 3-4000rpm, WTF and no codes.. Please Help.. (DX-R)
Another thing is that when I unplug the IAC my idle goes down to 1000rpm and then jumps to 2000rpm and then back and forth, and then when I plug it back in it shoots back up to 3-4000rpm... anyone with any ideas???
Old Aug 8, 2002 | 05:46 AM
88_SC_CRX_Si's Avatar
New User
How does it respond, when you try to set the idle using the air screw, does it have any effect on the rpm?
Old Oct 7, 2002 | 06:14 PM
4G-CIVIC's Avatar
New User
I also have the exact same problem. I have also done the same checks over the system, changing IACv, ecu, etc.
Old Oct 7, 2002 | 06:20 PM
Jared's Avatar
Put on a new fast idle valve.
Old Oct 7, 2002 | 06:29 PM
altoid's Avatar
Default Re: Idle at 3-4000rpm, WTF and no codes.. Please Help.. (Jared)
well i finished installing my zc the other day, and i had an idle between 1500 and 1750, and i do not know what the problem was, then now its at 500 rpm, and almost stalls out when i turn the wheel so now i have to adjust the idle nut. Its kinda odd. I was living in a fantasy world, i was pretending my cam was a racing cam, you know idling all fast and all, so if you can't figure it out, just pretend.
P.S. god im a post *****
Old Oct 7, 2002 | 06:40 PM
johnzm's Avatar
Default Re: Idle at 3-4000rpm, WTF and no codes.. Please Help.. (altoid)
i had my throttle cable too tight. it was doing the same thing. i drove me nutty cause i ahd all the vaccum lines right and everyhtring
Old Oct 8, 2002 | 06:37 PM
altoid's Avatar
Default Re: Idle at 3-4000rpm, WTF and no codes.. Please Help.. (johnzm)
I completely disconnected my fast idle valve, my idle fluctuated between 1000 and 1.5k then when i connected the throttle body (the big guy that says pgm-fi) to it it went to 1k then warmed up and idled to 500. which was a lil low since when i turned my steering wheel my car almost stalled. Then i connected this lil tube that was connected to this thing (god i wish i knew the name, its right above the throttle, connected to the firewall, on a 4th gen civic) to a T connector i installed on the FIV and everything went to the norm. idle at 750 and no more almost stalling. So take it for what its worth
[Modified by altoid, 10:39 PM 10/8/2002]
h-o-n-d-a
Aug 3, 2009 05:15 PM
95dc2teg
Sep 11, 2007 05:49 PM
madcrossover
Jul 2, 2005 10:18 AM
QWKPHKR
Aug 12, 2003 06:32 AM
QWKPHKR
Aug 11, 2002 11:35 AM
