jdm h22 wont start
i got a jdm h22, the car ran fine before no problems, i decided it was time to do a tune up and that where the problems began. I replaced the spark plugs..then i did the distibutor cap, hook up all the wires correctly 1-3-4-2 and now wont start, i had to use a 90-91 accord distibutor cap, it looks the exact same i took it back to napa cuz the car wouldnt start they said there should be no problems...if i use this cap would i have to replace the rotor with a accord rotor??? I have no idea what is going on with my car..I then took the spark plugs out regapped them at 0.40 they were at 0.44 but the ones in it before were at 0.40. I noticed that only the spark plugs near the alternator had black on it on the others had lilttle if none. i would use my old cap for now but it got broke.
ANY HELP WOULD BE nice please thanks alot...
take off one plug wire, jam a screwdriver in there, and hold the shaft 1/4" away from and engine ground and get someone to crank the motor - if you get spark, then you know your firing order is messed
