Integra AC pump on Civic lines?
Old Jan 30, 2009 | 10:10 AM
thumper64's Avatar
Default Integra AC pump on Civic lines?
If you swap the engine in a Civic that came with a SOHC engine to a DOHC, instead of buying a Del Sol or CRV AC bracket, could I just use the Integra AC bracket and AC pump and attach it to the stock Civic lines?
I pulled the AC lines out of a Civic already, and I have the Integra AC bracket, and a Civic AC pump. The price of the bracket looks about the same as a pump. Would this work and is there any reason not to do it this way?
Old Jan 30, 2009 | 10:39 AM
B18CivicEJ8's Avatar
Default Re: Integra AC pump on Civic lines?
The only way this will work is if the lines are out of a 99-00 Si. That is the only civic that used the same compressor as the Integra.
Unless that is a 99-00 Si Civic compressor, there is no way it will work. Try to match up the bracket with the compressor. You will see that it won't fit.
So long story short:
Integra Compressor, Integra Bracket, 99-00 Civic Si lines.
Civic Compressor (except 99-00 Si), CRV or Del Sol Bracket, Civic lines (except 99-00 Si)
Old Jan 30, 2009 | 10:40 AM
thumper64's Avatar
OK, thanks man.
Turbotype
Dec 2, 2004 03:02 PM
StreetProjectz
Sep 26, 2003 01:45 AM
