Left Low Beam Headlight not working...
Old Jan 30, 2009 | 08:29 AM
BiG_DeE's Avatar
Default Left Low Beam Headlight not working...
My left low beam doesnt work, but if i turn on high beams it works. no other problems with headlights...
Im thinking possibly bad ground???
i also notice that not all the time, but sometimes, my front blinkers stop working.. never both of em just one or the other...
my car is a 95 ex - ive checked all fuses of course.
Old Jan 30, 2009 | 08:30 AM
boost and bass's Avatar
Default Re: Left Low Beam Headlight not working...
try changing the bulb
Old Jan 30, 2009 | 08:40 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
switch the bulbs side to side and see what happens.
the turn signal could either be submerged in water from a leaky seal or the connector could be corroded.
Old Jan 30, 2009 | 08:41 AM
BiG_DeE's Avatar
Already changed both, sorry just thought about that right before u posted.
Old Jan 30, 2009 | 10:09 AM
danomatic93's Avatar
Check the wiring harness. Sounds like it got cut somewhere. Have you ever had water damage?
Old Jan 30, 2009 | 10:13 AM
BiG_DeE's Avatar
From what i understand the car has had water damage, it was leaking it in through the heater blower motor.. wheres the harness? the whole thing under the dash? :S
Old Jan 30, 2009 | 10:22 AM
HondaGuy951's Avatar
omg how dumb are you people?! Headlight bulbs in his car have 2 fillaments! 1 for high beam and the other for low.....and since you use ur low beams more than high, omg, his low beam fillament blew before his high beam one did! Jesus Christ!! Replace the fvcking bulbs! problem solved!
Old Jan 30, 2009 | 10:33 AM
BiG_DeE's Avatar
And you must be illiterate? Go read the postings you idiot.
Old Jan 30, 2009 | 10:58 AM
jimmy o.'s Avatar
my bet is your pigtails are corroded thats what was wrong with mine similar problem
Old Jan 30, 2009 | 12:54 PM
BiG_DeE's Avatar
my what???
Old Jan 30, 2009 | 05:14 PM
jimmy o.'s Avatar
the connector behind the bulb holder
Old Jan 31, 2009 | 12:05 AM
BiG_DeE's Avatar
It does look like its got like goopy stuff on it, and its not clean, im gonna use some electrical cleaner on it tomorrow, or brake cleaner. which ever i have.
Old Jan 31, 2009 | 12:17 AM
NewUnit16's Avatar
hook up a multimeter to the contacts in the pigtail, should be rather obvious if its a wiring problem then.
also, id still swap the bulbs (not for new ones, change the right to left and left to right) it could be possible that something is causing the low beam to pop. and CHANGE the fuse, if you just checked it. if you changed it, id change it again (or get a fuse tester) fuses can "look" good, but not be working properly. achems razor my friend.
Old Jan 31, 2009 | 07:48 AM
MoreBoost!'s Avatar
Might want too read before posting just made your self look like an ***. Anyways this happen to mine before. It was the harness being worn out . All i did was spray abit of cleaner and use a small screw driver to bend the tabs in for a firm fit. Try that first see what u come up with.
Old Jan 31, 2009 | 08:00 AM
jimmy o.'s Avatar
i just stuck some peices of copper wire in mine worked perfectly have had no problems since
Old Jan 31, 2009 | 02:02 PM
BiG_DeE's Avatar
i tried electric parts cleaner no difference, i still gotta try the multi meter..
unclematt
Sep 1, 2016 09:39 AM
Mrmatt3465
12
Mar 28, 2009 02:27 PM
dwss
Honda Civic (2001 - 2005)
Jul 22, 2008 08:20 AM
erikiksaz1
Apr 11, 2006 01:31 PM
jayare05
Feb 26, 2005 10:50 PM
