Piston to wall clearance with JE Pistons?
Old Aug 7, 2002 | 07:38 PM
Ri5e's Avatar
Default Piston to wall clearance with JE Pistons?
I was wondering that the recommended Piston to wall clearance should be with JE Pistons? I checked the clearance for all of them and it looks like they average around .005 inch to .006 inch?? I think JE recommended like .003 inch or something?
Also, I pushed on the top of the piston on one side and the piston seems to "move" over a little bit is this normal?!
Old Aug 7, 2002 | 07:45 PM
Flamenco-T's Avatar
Default Re: Piston to wall clearance with JE Pistons? (BG Boost)
the safe range is about .003 -.004 " with .0035 being nominal..
my wiseco's are .003"
Old Aug 7, 2002 | 07:48 PM
Ri5e's Avatar
Default Re: Piston to wall clearance with JE Pistons? (Flamenco-NA)
And this was with measuring the clearance at the top with a feeler gauge
Old Aug 7, 2002 | 07:54 PM
Flamenco-T's Avatar
no, you measure the PISTON Skirt to the cylinder wall...
you should have a spec sheet from JE that tells you at which point of the piston skirt you should measure the clerance from...
mine is about 1/2" from the lowest point of the piston skirt..( I think, I'll double check in a few)
stan
Old Aug 7, 2002 | 08:31 PM
Ri5e's Avatar
ohhhhh! Yeah I got the sheet, I didn't understand what that meant, haha. It says to measure some distance from the skirt. I'll do that tommorow. Thanks!
DC4 Rasta
Jan 5, 2007 06:44 PM
ZzZCivicZzZ
Mar 15, 2006 07:24 AM
supergreenNA1
Mar 24, 2002 09:59 PM
supergreenNA1
Mar 24, 2002 02:19 AM
