ctr or regular b16 pistons in itr block?
Old Jan 29, 2009 | 08:03 PM
JDM Lyfestyle's Avatar
Default ctr or regular b16 pistons in itr block?
Im wondering what would be the best idea for pistons in my itr block..ctr pistons or regular b16?what would be the results of each?
Old Jan 29, 2009 | 08:10 PM
SOHC_4dr's Avatar
Default Re: ctr or regular b16 pistons in itr block?
ctr will give you higher compression. also check wikipedia for the all the info on the diff B series motors or google. search FTW!
Old Jan 29, 2009 | 09:22 PM
93egSLEEPER's Avatar
what head will you be running?
i would go with some ctr pistons... makes a good piston for all motor build.
b16 pistons are so-so.
Old Jan 29, 2009 | 09:35 PM
ALLxMOTOR EG's Avatar
Vietnamese!
CTR would definately bump on the compression.
Old Jan 29, 2009 | 09:43 PM
GSR-EG-92's Avatar
Check out The Zeal compression calculator to see how high it would be. With my full B18C I was running 13.22:1 compression with PCT (CTR) pistons so I had to buy a thick cometic head gasket to lower it to 12.23:1. On 94 octane I can just get by.
yes just i dont reccomend them with a gsr head
Old Jan 31, 2009 | 05:51 PM
97 JDM ITR motor,just ctr pistons and skunk2 stage2cams and valvesprings/retainers.
what would be my compression ratio?I cant find this zeal thingy GSR-EG-92 mentioned
rex89sir2
Apr 23, 2008 06:30 AM
GSR_hatch936
11
Jan 10, 2008 12:06 PM
duRritztiNy
35
May 16, 2003 10:36 PM
zentraedityper
Jun 16, 2001 04:32 PM
