STR pro drag manifold. No Throttle cable bracket??
Old Aug 7, 2002 | 07:09 PM
Ri5e's Avatar
Default STR pro drag manifold. No Throttle cable bracket??
I'm in the process of installing the STR PRo drag manifold and I noticed there is no throttle cable bracket like the stock one on the LS. How do i connect it?
Old Aug 7, 2002 | 07:15 PM
ichibanjap's Avatar
Default Re: STR pro drag manifold. No Throttle cable bracket?? (BG Boost)
A friend of mine had the same problem and he just had someone custom make one or took the stock one and weld it on there. It worked out pretty good, and somehow they put it on the bottom so it's hidden, looks pretty cool..
Old Aug 7, 2002 | 07:58 PM
Ri5e's Avatar
Default Re: STR pro drag manifold. No Throttle cable bracket?? (ichibanjap)
damn. sounds ghetto. I dont wnana make my STR look ugly
Old Aug 8, 2002 | 12:00 AM
ichibanjap's Avatar
It's underneath the manifold so you can't even see it. Just an option, if you don't like it don't do it. Only trying to give you an idea that my friend did and it doesn't look ghetto, honestly you cant even tell it's there.
Old Aug 8, 2002 | 12:48 AM
Blown90hatcH's Avatar
Run a GSR throttle cable, bracket(that hooks to gsr TB). We had to do that once to make one happen in an EG.
Old Aug 8, 2002 | 06:24 AM
Mikey3000's Avatar
you have to buy the throttle cable bracket separately. it took me about 3 months to figure out how that stupid thing worked.
Old Aug 13, 2002 | 07:59 PM
Ri5e's Avatar
Default Re: STR pro drag manifold. No Throttle cable bracket?? (Salvatore Leone)
cool, I custom mounted it under the manifold
I just found some brackets and got creative
1badteg
Dec 19, 2006 06:57 PM
kcjohnnyboy
Sep 21, 2006 12:01 AM
JDM00SI
Jan 22, 2006 02:06 PM
b18psi
Sep 8, 2004 12:09 PM
NeXtLeVeL_TyPe_R
Nov 6, 2001 07:36 PM
