wtf is up with this crank?
Old Jan 29, 2009 | 06:33 PM
japscrap's Avatar
Default wtf is up with this crank?
Is there something wrong with this crank? If so how can I fix it? (besides being dirty lol)
Is there anything I should look for? Also how do you differentiate a H23 crank from an H22?
Old Jan 29, 2009 | 06:57 PM
98vtec's Avatar
moderator emeritus
Default Re: wtf is up with this crank?
crank looks done to me. have it inspected by a machine shop.
Old Jan 29, 2009 | 06:58 PM
japscrap's Avatar
done as in junk?
Old Jan 29, 2009 | 09:31 PM
techalude's Avatar
It might be resurfacable, but im no expert in machining
Old Jan 31, 2009 | 10:03 AM
duanes's Avatar
If you can "see" a problem, then it's likely toast - The tolerances on a crank are very tight... but - a machine shop can often resurface bearing issues (as mentioned above). But, when you put it back together, you will need to use bearings designed for this. The machine shop will machine 10 thousandths or something metric off and the parts shop can order your bearings with the same spec (ie..10 thousandths over).
If it is bent or other damage it is very difficult to fix. If you start spinning a crank assembly at 7000 RPM and it is bent or out of balance, there will be terrible vibration followed by a the spectacular appearance of an oil slick on the road (in James Bond Style).
Old Jan 31, 2009 | 11:13 AM
japscrap's Avatar
Its just the bearings. The crank is otherwise fine. Ive been looking for oversized H23 bearings would Honda have them?
Old Jan 31, 2009 | 06:56 PM
98vtec's Avatar
moderator emeritus
so you are trying to say that the crank in these pictures is "otherwise fine."
sure....if you like using reground cranks that originally looked like they went through hell and back. 1) There are metal shavings all over the crank 2) look at the main seal journal, there are two grooves of shittastic love 3) you can find good used cranks for under the amount of money it would take a machine shop to get that crank even close to what "I" would call useable. Those mains have excessive wear and i would not reuse it even if a machine shop could regrind it.
Old Jan 31, 2009 | 07:07 PM
japscrap's Avatar
I cant find them around here. Local junk and salvage yards either dont have one or want a bagillion dollars for one. "not so civic" has one on here for cheap.
Old Jan 31, 2009 | 07:09 PM
dagle's Avatar
just for my own knowledge enrichment blake, can you point out the grooves? I only noticed the bearings. just trying to learn what to look out for if I ever purchase a used crank
Old Jan 31, 2009 | 07:10 PM
japscrap's Avatar
The end with the bolts.
Old Jan 31, 2009 | 07:11 PM
dagle's Avatar
japscrap PM me with how much u wanna spend and contact info. I have a good one laying around from a motor where the pistons scored the cylinder (7PSI greddy kit untuned)
japscrap's Avatar
Do you have any pics?
hatchet_honda
Nov 6, 2009 08:26 AM
egcivic123
Jan 15, 2005 12:38 PM
hondaeg8
Feb 9, 2004 10:42 AM
garados
Jan 25, 2004 03:48 PM
92LudeSR
Jul 11, 2003 07:09 AM
