Car wont go in gear.
Old Jan 29, 2009 | 03:59 PM
IB4TL FTW's Avatar
Default Car wont go in gear.
I have not had any problems at all. The clutch has not slipped once. I was on the highway today, and when i attempted to shift from 3rd to 4th, the pedal stuck to th floor and it would not go into gear. after about three or four attempts i finally got it in gear. once i got off the highway, i was at a redlight and when attempting to put it in gear the car would just roll forward and stall. there was never any slipping or loss of power, it was a sudden thing? i am confused to what it could be. it was the first time i had the car out in about 2 or 3 weeks. i am thinking possible master and/or slave went bad idk? any ideas?
Old Jan 29, 2009 | 04:08 PM
slambedcivic's Avatar
Default Re: Car wont go in gear.
A few things to look for:
1. Look under the dash where you clutch pedal is. See fluid? Does it smell like brake fluid? If not then look elsewhere. If so, you need to replace your clutch master cylinder
2. Look at, on and around your slave cylinder. Refer to option 1 for instructions.
3. Have you bled your clutch lines recently?
4. If none of the above seems to be the answer. Then you need a new clutch kit. Maybe not the clutch disc is bad, but youre pressure plate springs are giving up and are binding causing your clutch to be constantly engaged.
Hope this helps. If you need more help be sure to ask
I bet if you shut your car off, you can put it right into gear with little to no effort at all.
Old Jan 29, 2009 | 05:06 PM
93monsterbubble's Avatar
mine did that last week, replaced master cylinder and slave cylinder, bled the lines, took half hour and was fixed.
Old Jan 29, 2009 | 05:09 PM
by the way i bought the cylinders on ebay for like $60. they work fine so far and looked quality, but ask me in a year i might change my idea whether it was a good buy or not..haha
Old Jan 29, 2009 | 05:29 PM
IB4TL FTW's Avatar
thanks for the help thus far, sounds like my thought of master/slave to be hopefully, wishfully correct.
Old Jan 30, 2009 | 05:30 PM
IB4TL FTW's Avatar
It was master and slave!!! on the good side it wasn't more expensive, on the bad it was 680 total including 1.5mile tow.
Old Jan 30, 2009 | 05:34 PM
Townson's Avatar
i'd say clutch master cylinder, same thing happened to my friend's civic.
Old Jan 30, 2009 | 10:25 PM
Reading surely owns you.
Old Jan 30, 2009 | 10:26 PM
HOLY CRAP! Thats expensive. I would have charged half that to do it.
Old Jan 31, 2009 | 12:32 AM
NewUnit16's Avatar
id have changed them for a case of beer and price for parts. then id have 22.5 beers to take home after i spent the hour changing them. man, you should splurge 20 bucks on a manual, it will save you hundreds down the road (in this case about 600 bucks)
Old Jan 31, 2009 | 07:34 AM
MoreBoost!'s Avatar
I hate to say it but.... u got ripped off . I'll drive up there and do it for u for less than that.
Old Jan 31, 2009 | 05:01 PM
IB4TL FTW's Avatar
i would have done it myself and as you can read my diagnoses was correct from getgo, its just that i did not have tools, parts, or a place to put the car and i was about 50miles from my home. i am not about to leave a kswap eg on the side of the roaad for any period of time...
Old Jan 31, 2009 | 05:07 PM
94excivic's Avatar
How much of that was for the tow/parts/labor? I am not familiar with a K-swap EG but I do know that it shouldn't have been that expensive. If the tow wasn't free get AAA. It's pretty cheap and the basic plan gives you 3 miles free towing.
Old Jan 31, 2009 | 05:15 PM
IB4TL FTW's Avatar
tow was 55$ I am going to get a breakdown of "their" charges tomorrow. I was just on honda.com parts store. the master was 124.09 and the slave was 80.23... 225 for parts! so parts plus tow is 280$...400 for labor and tax...
Rootie524
Transmission & Drivetrain
Sep 13, 2013 09:26 AM
new_climber
10
Jan 17, 2013 10:18 PM
jwshilli
Jul 14, 2009 03:02 PM
Luchini
Oct 16, 2005 11:15 AM
