Acceleration Problem
Hello guys, can you help me with my problem. I have a 96 vtec civic automatic and had it overhauled. Changed my piston rings and con-rod bearings and all gaskets plus changed my broken PCV valve and knock sensor and timming belt. Before that the car has an acceleration problem already so I thought of giving it an overhaul but after I did the car still has the acceleration prblem. The power I get is not enough when accelerating from stop as well as when I am already driving and step on the gss the car seems not to respond well. It is hard to overtake because of this problem.Can anyone tell me where and what to look at for this problem? I am not familiar with cars so I need your help please. It becomes worse when I drive with the aircon on.
By the way, someone told me to have my transimission oil and filter change. Will it solve my problem?
Hi guys, thanks for the replies. Can the fuel filter and catalytic converter be cleaned or do I have to buy new ones?
Another, does pcv valve has anything to do with my acceleration problem?
Hope this helps.
tq converter, im 100 percernt sure if your motor is performing as it should, then your tq converter is faulty.
its located inside the tranny so you know.
what made me say this is your complaint of poor acceleration from a stop but once moving you have more power or feels better. thats a tq converter failure right there
to replace the trans filter you would have to open the case, you can do a fluid swap but its not gonna help.
also use only honda auto trans fluid
See bold print below. Yet again, another non reading member.
supertouch
Honda Civic (2001 - 2005)
11
Jul 20, 2007 10:19 AM
tmvijai
Mar 28, 2007 05:29 PM
