Any easy way to convert Hondata map to run in crome pro? Help asap!!
Hi all. Got a problem.
Need to put a cars S300 map into crome pro for a socketed ecu. Id just tune with crome bt datalogger is buggered so im stuck and have no time!!. Wondered if anyone nows an easy way i can transport fuel tables into crome pro from the s300 map i did on dyno today to save me tuning time. I had to use my ecu and hondata to map it u see but this car hasnt got hondata. Hopefully then i can just burn a chip and voila. Cheers Marc
It won't transfer right over, you'll need to do fine tuning. They use two different code bases and have different correction options.
No, it would seem that OBD1 fuel and timing is pretty much calculated the same between editors. It's corrections and other factors in the base code that make the difference.
I knew someone who owned a Dyno Shop in Arizona who told me once at SEMA that he would tune a car with the S300, and then copy/paste the maps over to Crome and do basic, basic fine tuning and throw the car out the door.
I wouldnt recommend this...
I can tell you for sure that this isn't me, I wont even touch Crome, or any of the freeware garbage.
My feeling is, if you like to tune on S300, make the customer buy it, or tell him to go elsewhere.
