When upgrading I/H/E.......
Old Jan 28, 2009 | 02:20 PM
Black95CivicEx's Avatar
Default When upgrading I/H/E.......
When upgrading I/H/E, where should I start???
Thanks for any and all input!
Old Jan 28, 2009 | 02:31 PM
dividedas1's Avatar
Default Re: When upgrading I/H/E.......
by taking off the stock stuff?
Old Jan 28, 2009 | 03:17 PM
Arthas's Avatar
10mm, 12mm, and 14mm bolts.
Do it in any order, it doesn't really matter.
Old Jan 28, 2009 | 03:20 PM
batallic's Avatar
intake first, then headers and exhuast
Old Jan 28, 2009 | 03:21 PM
Arthas's Avatar
Thats the order I did it in haha.. Megan Racing OE muffler, here I come!!
Old Jan 29, 2009 | 08:02 PM
Bondito007's Avatar
How much do I want to spend is the first thing you should ask yourself. When I had my GSR I got my header(DC Sports 4-1) and my exhaust(HKS Hiper) first. I knew those would cost the most so I knocked them out. Also consider this. If you get your intake first, your not going to get too much more air in if it has no where to exit so to say. I picked up a DC Sports DAC short ram for $50 when OptAuto had a clearance sale. And keep in mind that you get what you pay for.
Old Jan 29, 2009 | 08:56 PM
jsant07's Avatar
depends.....if you have a d series than what you would spend on a decent i/h/e setup you could probably get an ls swap for a little more which would be far more beneficial in the long run because not only would it be faster stock than a d with i/h/e you have alot more potential stock block....poor honda-tech
Old Jan 29, 2009 | 09:07 PM
xxblazexx's Avatar
set up your goals?
Do you want peak power if so get a 4-1 header. the OE ITR header is nice, and get a short ram air intake, you'll get good gains everywhere mostly in the higher end of your powerband
If you care more about the midrange then peak, get a 4-2-1 aka Tri-Y header and a normal CAI that goes into the fender, and with that you get a nice boost in the midrange
then budget.
Old Jan 29, 2009 | 09:15 PM
93egSLEEPER's Avatar
i think the intake sounds coolest
Old Jan 30, 2009 | 08:10 AM
Bondito007's Avatar
I forgot to ask what engine are you working with?
Old Jan 30, 2009 | 09:40 AM
dividedas1's Avatar
if it's a d-series i would start with a motor swap
header = pointless because turbo is the only way to really make power with a dirty d
intake = pointless see above
exhaust = about the only thing i would do if i was planning on keeping the car because it will work with a motor swap. and with a little bit of work it would work with a turbo.
Old Jan 30, 2009 | 09:41 AM
dividedas1's Avatar
hahaha true story, stupid 10 mil bolts. all over the place
Old Jan 30, 2009 | 10:46 AM
CountDracura's Avatar
If you intend on upgrading the header and exhaust, then I would recommend doing those at the same time. They are easier to install as a pair and will reduce labor time.
Old Jan 30, 2009 | 10:47 AM
bmoua's Avatar
what other mods do you have OP? i'd lower your car with a good rim/tire combo before i start modding the motor.
wegotmorrison
Aug 6, 2007 12:18 PM
joostan
Apr 12, 2006 08:26 PM
fuLLbLOWNgSR
Mar 10, 2005 11:00 AM
zojirushi
Oct 10, 2001 06:21 PM
mikeSONICGSR
Sep 20, 2001 07:49 PM
