ls vtec eg
Old Jan 28, 2009 | 01:15 PM
spicygirl's Avatar
New User
Default ls vtec eg
hi im a lil new to honda's i had an eclipse b4 n e ways i just got a hatch with an ls vtec in it motor was just put together and guy said vtec was wired right except for pin D on the ecu he didnt kno where it went its got jdm gsr ecu long story short vtec is not workin at all i got 4 cel light codes vtec soliond...... intake temp...... oxygen sensor heater.. idle air control sensor.. heard cel could be cause of vtec not working.. another note the lights on my instrument panel dont work cel light run signal all work just not speed and tach nor do winshield wipers need help with all these probelms please
Old Jan 28, 2009 | 01:30 PM
mcneil's Avatar
Default Re: ls vtec eg
He might have the IACV and IAT plugs reversed... Unplug them and switch the plugs.. Might solve that issue. IACV should have a green and white wire, while the IAT should be a red with a yellow line..
For vtec, it needs to be wired to D6..
the oxygen sensor could be becuase its not pluged in, or becuase it doesnt work anymore.
Old Jan 28, 2009 | 02:33 PM
spicygirl's Avatar
New User
do u or does n e one have a pinout for it not sure what to look for either ls vtec pinout or gsr inout since ecu is jdm gsr
Old Jan 28, 2009 | 07:29 PM
iliv2xlr8's Avatar
This isn't a text message.....
Please use punctuation properly.
Here you are:
http://www.phearable.net/tech/wiring/pinouts2.htm
Old Jan 28, 2009 | 08:54 PM
iamthefollower's Avatar
This might help you a little more than the other link...
Old Jan 29, 2009 | 04:49 AM
spicygirl's Avatar
New User
thanks for the ecu pinouts does any one no about the winsheild wiper problems or insturment panel
chancock
Sep 17, 2007 01:41 PM
vietblood87
Jul 14, 2007 09:58 PM
Ibanez
Sep 2, 2005 11:57 AM
soquickls
Jun 28, 2004 05:52 PM
mkim12180
Apr 8, 2004 08:30 PM
