ls vtec eg
ls vtec eg
hi im a lil new to honda's i had an eclipse b4 n e ways i just got a hatch with an ls vtec in it motor was just put together and guy said vtec was wired right except for pin D on the ecu he didnt kno where it went its got jdm gsr ecu long story short vtec is not workin at all i got 4 cel light codes vtec soliond...... intake temp...... oxygen sensor heater.. idle air control sensor.. heard cel could be cause of vtec not working.. another note the lights on my instrument panel dont work cel light run signal all work just not speed and tach nor do winshield wipers need help with all these probelms please
Re: ls vtec eg
He might have the IACV and IAT plugs reversed... Unplug them and switch the plugs.. Might solve that issue. IACV should have a green and white wire, while the IAT should be a red with a yellow line..
For vtec, it needs to be wired to D6..
the oxygen sensor could be becuase its not pluged in, or becuase it doesnt work anymore.
Re: ls vtec eg
This isn't a text message.....
Please use punctuation properly.
Here you are:
http://www.phearable.net/tech/wiring/pinouts2.htm
Here you are:
chancock
09-17-2007 01:41 PM
mkim12180
04-08-2004 08:30 PM
