Ebay OEM Engine Rebuild Kits??
Old Jan 28, 2009 | 09:02 AM
QuarterMileMaster's Avatar
Default Ebay OEM Engine Rebuild Kits??
http://cgi.ebay.com/ebaymotors/ws/eB...link:middle:us
This Engine Kit includes:
Pistons with Piston Ring Set (We have Standard or Oversize .020" = .50mm)
Oil Pump
Water Pump
Timing Belt Kit
+ Timing Belt
+ Tensioner
Engine Bearings (Source: Either from ACL or KING BEARINGS.)
+ Main Bearing Set (We have Standard or Oversizes: .010" = .25mm or .020" = .50mm)
+ Rod Bearing Set (We have Standard or Oversizes: .010" = .25mm or .020" = .50mm)
+ Thrust Washers (Standard only)
Full Gasket Set
+ Multilayer Steel Head Gasket
+ Intake Manifold Gasket
+ Exhaust Manifold Gasket
+ Valve Cover Gasket
+ Viton valve stem seals
+ Oil Pan Gasket
+ Front & Rear Main Seals
+ Water Pump Gasket
+ Small Components and Other Gaskets
All for $249 + $25 shipping.
You guys think this is safe/quality?
Old Jan 28, 2009 | 09:13 AM
Default Re: Ebay OEM Engine Rebuild Kits??
Woops, searched a little harder and found some threads on it. Nevermind.
Old Jan 28, 2009 | 09:19 AM
5.56's Avatar
Whats did you find out about it?
Old Jan 28, 2009 | 09:32 AM
lilsicsoul's Avatar
I wanna now 2
Old Jan 28, 2009 | 06:54 PM
5.56's Avatar
Let me know because I've been trying to research it, but so far no luck.
d0wnShiFt
Jan 13, 2011 05:30 AM
EG_Civic_Si
Oct 31, 2005 03:13 PM
platinum00
Dec 1, 2004 11:15 AM
schwett
Apr 24, 2002 08:37 PM
