high compression + boost
Old Jan 28, 2009 | 07:24 AM
stefz's Avatar
Default high compression + boost
hi there i noe that high compression + boost isnt a good thing but i was looking at these pistons http://www.ariaspistons.com/products/acurahonda.html for my d16 build and they are selling 11.5 Cr pistons and say its for turbo/n2o just wondering ur thoughts on this, and has anyone boosted anything with such high CR.
thanks
Old Jan 28, 2009 | 09:32 AM
z6hatchboy's Avatar
Default Re: high compression + boost
its just a selling gimmic, sure they could be used with boost/nitrous but its very unpractical at compression that high. Technically you can run boost with any compression but you have to have octane high enough to support it, which isnt available a lot of the times so thats why 8.0:1-9.0:1 is generally the more accepted compression for boost because you use pump gas easily with that and a good tune. If you're wanting to boost your d cheap then look into a vitara setup, you can check the one in my sig i done for more info on it
Old Jan 28, 2009 | 09:59 AM
stefz's Avatar
yea thanks 1 more thing i was looking at sleves and they sell 75 mm but the pistons im looking at or 75.5 mm what do i do im a noob at rebuilding
Old Jan 28, 2009 | 10:26 AM
z6hatchboy's Avatar
Sleeving usually costs around 1100, they can bored out a certain amount which is usually a few mm so thats no problem. But theres guys that are hitting 400hp without sleeves in d series
Old Jan 29, 2009 | 08:22 AM
stefz's Avatar
do u recomend sleveing then, b/c this car is going to driven daily and i just want to be safe yr round
gs1gsr
Aug 19, 2012 05:42 PM
snaileg
Nov 8, 2006 04:11 PM
7rrivera7
Apr 20, 2004 03:46 AM
thinkbrianthink bu
Oct 13, 2002 10:47 AM
AzN_Flava
May 12, 2002 05:35 PM
