Help!!!!!!!!!
Old Jan 28, 2009 | 06:33 AM
95f22a1's Avatar
Default Help!!!!!!!!!
i got an 88 dx hatch with a 92 da rear disc swap. my right rear wheel is bouncing, i got brand new tires, just balanced, brand new wheels. any reason to why my wheel is bouncing?
Old Jan 28, 2009 | 09:34 AM
MyHotsh's Avatar
Default Re: Help!!!!!!!!!
Blown struts??? maybe!!
Old Jan 28, 2009 | 10:20 AM
FG2-AutoXer's Avatar
you check how tight the ball joints were, could be control arm bushings, tophats, blown struts, worn out springs, is it a hard clunking sound that's made when it does it, could you explain a little more about the bouncing
Old Jan 28, 2009 | 10:50 AM
95f22a1's Avatar
yeah its bouncing and making a ting ting ting noise but i checked the lug nuts and they were all tight.
Old Jan 28, 2009 | 10:58 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
You need to take two seconds, put that corner up on a jack, and then pull/push/twist from 12, 6, 9, 3, etc etc (two hands, one at each spot) and see what gives (literally)!
Old Jan 28, 2009 | 11:18 AM
95f22a1's Avatar
ok well i just check the brakes and replace the rotor and pads cause the were wore out. the rotor had a lip and the pads were wore to metal. i just got the car. do you think thats what could be doing it?
Old Jan 28, 2009 | 11:26 AM
possibly but not likely, check for play in the ball joint and check the upper mount as well for tightness see if the bushings on the control arm are worn, that's what it sounds like to me
D j
Aug 14, 2011 12:28 PM
FRKWOO
20
Nov 25, 2009 12:13 PM
slambedcivic
26
Nov 5, 2006 05:57 AM
track_assassin
11
Jan 26, 2006 03:38 PM
Veil_Side_
Apr 9, 2002 12:20 PM
