4500k Limiter Vtec not engaging?
Old Jan 27, 2009 | 11:39 PM
hondarazor23's Avatar
From: You may think I can't see you..but in reality..I could see you very clearly..
Default 4500k Limiter Vtec not engaging?
I have a 1994 accord ex 5 speed. rev limiter at 4500k? it has enough oil. I doubt its the ecu. seems like vtec isn't engaging, that is the range where vtec is suppose to engage and when i rev up to 4500k in all gears it hits a limiter forcing me to switch gears or slow down. any ideas suggestions are greatly appreciated.
Old Jan 28, 2009 | 05:01 AM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: 4500k Limiter Vtec not engaging?
Not throwing a CEL?
Old Jan 28, 2009 | 05:33 AM
Ross 2.0's Avatar
In a Junkyard near you.
Usually the distributor is on it's way out when this happens.
Old Jan 28, 2009 | 07:05 AM
P_Adams's Avatar
You need several conditions met for Vtec to operate:
A) Correct Oil pressure - if you don't have enough oil pressure, it won't engage.
B) Correct Engine Operating Temp
C) Closed Loop ECM, No codes
D) No VSS issues.
If you're dealing with a "Check Engine" lamp, fix it.
Check the Vtec solenoid for the signal from the ECM
If a signal is confirmed check:
Vtec Solenoid for debris (oil ports)
Vtec Control Switch for blockage
P
Old Jan 28, 2009 | 11:38 AM
^ i'll give that a shot. no CEL light at all
Old Jan 28, 2009 | 11:57 AM
can't be that i just replaced the whole distributor. It had the 4500k limiter before that as well.
Old Jan 28, 2009 | 12:34 PM
Targa250R's Avatar
be professional
When did this problem start? Did you do anything at all to the car prior to the problem appearing?
Barring a wiring or modification issue, it is likely that the VTEC spool valve gasket screen is clogged or the solenoid itself is bad. I've seen a handful of bad spool valves on '98-02 Accords and '02-06 CR-Vs, but not so much on the '94-97s.
Try cleaning the screen on the gasket. If that doesn't work, try a used spool valve from a salvage yard.
Old Jan 28, 2009 | 12:48 PM
Nope not at all. Bought the car from a 35yr old military man 8 months ago. He barely drove it, there could be a possibility that there might be some clogging. But does having a 4500k limiter sound like a Vtec problem?
Old Jan 28, 2009 | 12:53 PM
Targa250R's Avatar
be professional
Yes.
Old Jan 28, 2009 | 12:56 PM
do you have a spool valve and/or spool valve gasket screen diagram ? thanks man
Old Jan 28, 2009 | 02:12 PM
P_Adams's Avatar
Refer Post #4
It's direct from Honda Parts Division
P
Old Jan 28, 2009 | 03:06 PM
k
Old Jan 28, 2009 | 07:31 PM
hmm..after doing some research, switching out or cleaning the spool gasket seems fairly easy. Im going to try that, if still no luck then im going to try switching solenoids.
I hope mine looks like this, that way i could confirm that the clogging is the cause:
Old Jan 29, 2009 | 07:53 PM
hon2984's Avatar
If that doesnt work, see if you can find a known good ECU to swap out and try!
My car did the same thing except it was at 3500 rpm. Swapped out the ECU and it fixed the problem.
Pleiadi79
Jun 12, 2008 08:22 AM
soloteg2
Apr 9, 2006 10:58 AM
mister2racer
Jun 26, 2005 07:13 PM
salman
Mar 14, 2005 12:43 AM
zer0zer0 TypeR
Jun 6, 2002 04:53 AM
