white smoke out the exhaust...
i know it usually means a blown head gasket...coolant burns white out the exhaust...
compression is fine, oil looks fine...coolant is semi dirty...can't really tell if there's oil of not
what else could white smoke mean? engine runs pretty rough
update...there's actually oil coming out the exhaust...pure oil dripping from the header/test pipe joint...and no, its not leaking from somewhere, its actually coming from inside the header....
whats wrong?
whats wrong?
Could your valvetrain be leaking oil into the exhaust ports?
It's the only way I can think of oil getting into your manifold, besides bad pistons rings.
Just trying to help...
in the process of pulling the head...
i probably blew a ring...but we'll see....its a brand new motor so i dont think the valvetrain would be leaking
how do you tell if a ring is blown?
pulled the head, can't see anything...
i have a spare short-block...so its gonna go in
import races are friday
should be interesting to see if i can get it done
Redprelude98
Nov 25, 2008 10:42 AM
