Damaged 95 dx coupe
Old Jan 27, 2009 | 08:05 PM
DWOL's Avatar
Icon6 Damaged 95 dx coupe
Hi im about to buy this car for about 700 engine and everything is all good except for the radiator, AC and front end damage i want to try to fix it myself but i dont know what that front part in between the headlights is called to get a replacement. can somone help me out? thanks in advance
heres sum pics:
https://honda-tech.com/attachment.ph...1&d=1233119072
Old Jan 27, 2009 | 08:21 PM
egownsu's Avatar
Default Re: Damaged 95 dx coupe
that piece is called a radiator support. i had to replace that along with fenders hood and f. bumper a year ago in an accident i had
Old Jan 27, 2009 | 10:02 PM
DWOL's Avatar
Thanks how much does the radiator support run for?
Could i get one at a junkyard or ill have to order one online?
Old Jan 27, 2009 | 10:09 PM
ChuckNorris's Avatar
looks like frame damage on the passenger side fender frame.
i wouldnt buy it.
Old Jan 28, 2009 | 11:27 AM
DWOL's Avatar
i wouldnt buy it.
Cant the fender frame be replaced? or is it a actual piece of the whole frame.
Old Jan 28, 2009 | 01:39 PM
Disease's Avatar
That would need to go on a frame machine to pull the sway and the mash out of it. Baisically your front rails look like they are pushed in one direction and back on one of them.
The upper apron is bent as well. There is alot more there than just welding on new parts and bolting on new parts.
None of the frame of the car is bolt on. It is all welded. So no you can not just replace it without pulling it first and then cutting it out and welding a new one in.
It is not a seriously difficult repair but if you do not have a frame machine then it could be a bit harder to get everything to fit up.
I would not buy it if you do not have the tools to fix it properly. Would turn into a bigger headache then you think.
Old Jan 28, 2009 | 02:14 PM
joey1320's Avatar
why is the oil cap off?
Old Jan 28, 2009 | 03:21 PM
shocker911's Avatar
X2....def would be a nice pull on that car to fix the damage on the pass. side. pass this up unless you can part the car for more than you pay for it
Old Jan 28, 2009 | 09:14 PM
DWOL's Avatar
Well im getting the car for 715. And this is kind of my only choice right now because my civic got stolen on friday so basically i need a car as soon as possible. im still not sure what im going to do yet.
Old Jan 28, 2009 | 09:15 PM
DWOL's Avatar
Thats what happened from the crash. Engine runs fine but oil cap came off and oil spilled everywhere.
Old Jan 29, 2009 | 04:25 PM
clean3two3's Avatar
seriously dont buy this
Old Jan 30, 2009 | 12:45 AM
MasterLsGod's Avatar
go rhd
Old Feb 2, 2009 | 05:00 AM
19civic93's Avatar
This is not worth fixing. The parts will be worth more than the car itself. A new front clip which includes the radiator support, radiator, lights, condenser, hood, fenders, and bumper will run you around 700-800. Add that to the 715 you paid for it and you could buy another dx that fully intact. Plus you would still have pay to paint it or at least the new parts.
But if you do decide to buy it, this is not a hard fix at all if you have the equipment. Frame should be straight. The passenger side doesn't look too bad and can be fixed. Infact if you buy a complete front clip, that part of the frame the passenger fender mounts to will come with it and you can cut it off and weld it on. I'm repairing a Prelude right now and the front is a lot worse than that. There is no frame damage on this. I just finished the repair and now I'm starting on the bodywork and paint. It will be a color change when I'm done. In my case it's worth fixing because of the resale value. I got this car back from insurance for 800. Here's some pics to motivate you if you buy it.
Old Feb 2, 2009 | 05:02 AM
19civic93's Avatar
More
Old Feb 2, 2009 | 11:12 PM
DWOL's Avatar
Wow thanks that helps alot.
I did endup buying the car i juss needed a car quick since my previous civic was stolen.
The day after i bought it my other civic ws found but the whole inside was stripped. cost me 375 to get it out the impound. so now i have both. But with the 95 civic i have a problem it overheats and i swapped the radiator and im pretty sure that radiator is good but im not sure i juss took it out of the stolen civic and it worked before so i assumed it would work. But the problem is that the fan does not turn on at all. and the car just over heats. i thought it might be the thermostat so i replaced that but still the same problem. what could cause this? is there any tests i can do to check. or even to check if the fan even works. Thanks
Old Apr 3, 2009 | 08:28 AM
jdmjoka's Avatar
DB squad #282
your crazy
jzavala
Paint and Body
Dec 8, 2017 11:55 PM
MUGEN_EG95
Sep 18, 2008 08:56 PM
SIRIUS VTEC
Jun 8, 2008 12:14 PM
potential
May 20, 2006 08:26 PM
GunnaGetOne
Sep 29, 2003 11:32 AM
