f22 auto trans into a 6th gen (searched.. )
Old Jan 27, 2009 | 07:30 PM
1320ms's Avatar
Default f22 auto trans into a 6th gen (searched.. )
tried searching, however I was unsuccessful
I know an f22 trans will bolt up to an f23, but will it work exactly the same? Are the torque converters interchangable? Will everything plug right in? Is the gearing similar? Use the same diameter/spline axle?
And if so, why would/should/could I not replace my dying f23 auto with an f22 auto?
And no, I dont want to convert to manual, the car is strictly a commuter..
Old Jan 28, 2009 | 09:37 AM
AFAccord's Avatar
Default Re: f22 auto trans into a 6th gen (searched.. )
If I'm not mistaken, the F22 trans' use a separate transmission control module (TCM), while the F23's have the TCM built into the ECU.
I wouldn't think it would work because the F23 ECU won't run the car correctly if it doesn't see the trans, and the F22 TCM probably needs some sort of input from the ECU which the F23 ECU won't provide because it wasn't designed for an external TCM. /run-on sentence
I don't think it will work.
Old Jan 28, 2009 | 10:04 AM
raceACCORDingly's Avatar
you are correct. however the 96-97 f22bx auto trannies also have the integrated TCM.
Old Jan 28, 2009 | 03:35 PM
1320ms's Avatar
Thanks guys
so in theory, would a 96-97 F22 trans work?
Old Jan 28, 2009 | 05:58 PM
brianpierce's Avatar
It's a MANUAL Trans!
Old Jan 28, 2009 | 05:59 PM
AFAccord's Avatar
Blind or just stupid?
Old Jan 29, 2009 | 06:08 PM
Cannon Man's Avatar
^Both maybe?
Thats what it looks like. Try it and see...you'd be the first.
Old Jan 29, 2009 | 06:17 PM
OK, I've got all gear spec's for my 91 Accord MANUAL trans. If anyone has the Honda book for 94-97 please let me know. Thanx
Old Jan 29, 2009 | 08:00 PM
Cannon Man's Avatar
^^^What the hell are you even talking about? Just go look at the FAQ for your ratios.....Jesus
slowDB7
Feb 25, 2013 07:43 AM
jack sparrow
Aug 28, 2009 08:24 PM
akouznet
May 24, 2009 06:50 PM
scuzz
Sep 24, 2008 02:45 PM
Budget Racer
14
Apr 30, 2007 02:55 PM
