Straping down car on trailer with traction bars
Old Jan 27, 2009 | 01:07 PM
Civic89stdB16's Avatar
Default Straping down car on trailer with traction bars
Hey where r u all hooking the straps, chains and binders to when ur car is on the trailer if u have traction bars with no tow hooks. Thanks
Old Jan 27, 2009 | 01:25 PM
rota92
Guest
Posts: n/a
Default Re: Straping down car on trailer with traction bars
Axle straps right around the front bar, then chains or straps forward.
Old Jan 27, 2009 | 01:46 PM
1992Si's Avatar
Something like this. Ryan like the ones with the sleeves over them. There about $7.50
http://www.tractorsupply.com/webapp/...g=true&cFlag=1
easternmarine.com is another place I've found that has some good pricing.
If this is your first time doing this. Go to a local trailer place and see what they recommend. They know what will work. Also I believe some states have laws that you need to be aware of.
This is one area you want to be safe in. If you go cheap and something breaks and the car
moves and gets damaged, how much did you save?
We use crossed ratchet straps to hold the rear down, and 1/2 chains with adjustable pins and quick lease pins for adjustment on the front. I'll see if I can find a photo.
http://i185.photobucket.com/albums/x...i/DSCF0410.jpg
Not very good but:
http://i185.photobucket.com/albums/x...cture015-1.jpg
These rear straps wrap around the LCA and hook back to themselves. I can kind of see that under the car.
Old Jan 27, 2009 | 01:48 PM
InDub's Avatar
Just use the tow hooks built in to the traction bar ??
Old Jan 27, 2009 | 01:51 PM
1992Si's Avatar
Not all bars have the holes built in. Our Full Race didn't, but I think they do now.
Old Jan 27, 2009 | 02:45 PM
so ur putting the axle straps over the traction bar in the front. i will criss cross the rear straps.
Old Jan 27, 2009 | 02:50 PM
JBLAZE622's Avatar
just go around the front control arms just dont go nuts when u tighten them
Old Jan 27, 2009 | 02:55 PM
1992Si's Avatar
That's what we were told by the place we bought the open trailer from.
When I tie my Legacy down I go around the LCA on both ends. Like JBLAZE622 said.
Old Jan 27, 2009 | 03:03 PM
Turbo-charged's Avatar
i watched this show on TV once about how they transported all the zillion dollar rare exotic cars. if the car did not have open wheels on it, they would put a set on temporarily just so they could strap the cars down going through the wheels. they wanted the cars suspension to still be able to function like normal. makes sense.
Old Jan 27, 2009 | 03:10 PM
redboost10's Avatar
speaking of that, quite a while ago, there was an article in some hotrod magazine mentioning that a dragstrip only car's suspension will take more of a beating in the trailer than at the track during its life...
Old Jan 27, 2009 | 03:22 PM
boostedcivicsir's Avatar
Mr. Badwrench
i used to do it like that, but opted to use the lower control arm, and the rear frame ties. still ets the suspension work, instead of pancaking the car.
Old Jan 27, 2009 | 03:53 PM
Innes's Avatar
we have a custom built traction bar on the our car -- tow hooks of course were added as a neccessity to strap the car down -- makes it a lot easier for the front
for the rear we strap to the LCA's
people used to ask us all the time how streetable the Strange Double Adjustable coilovers are -- with the car riding in the trailer they are taking a beating so I would guess ours have about 50k miles on them and are still holding up great
Old Jan 27, 2009 | 04:28 PM
mike93eh2's Avatar
my full race bar has tow hooks but i have always just looped the strap over the bars on the traction bar.
Old Jan 28, 2009 | 12:25 AM
so when i strap the car down with the lca's don't make them crazy tight. should i tighten it all the wayuntil the car wont move and then a extra pull on each. I do tow demo derby car alot because its the other hobby i have but i strap or chain cars down for that and i use the frame or rear and squat the suspension as much as i can because thats what i was told by people to do and the cars going to be trashed in less then 30 minutes in a heat anyway. For the ones using axle straps around the traction bars arn't u worried about the bars breaking and ur car possibly going off the trailer. Thanks
Old Jan 28, 2009 | 02:33 AM
1992Si's Avatar
You wrap the strap around the big cross bar not the rods with the hiem joints.
Three ways of looking at the where to pull from;
tie the frame down like you would a box box and the trailers suspension carries the wieght.
tie the car from the the LCA's and the cars suspension carrys the car.
Use some of both and the load is slpit betwen the car and trailer.
IMO what ever works for you is the way to go. If there is a major problem with either way of doing it, there would be a federal law stating how to do it.
Old Jan 28, 2009 | 08:33 AM
thanks for all the comments.
2cams
Southeast
10
Feb 16, 2012 04:20 PM
blackccoupe
Dec 28, 2008 09:57 AM
JDM00SI
Nov 11, 2005 06:21 AM
HondaJon
Jun 22, 2003 10:32 PM
Robb
Sep 23, 2002 12:39 PM
