fuel filters?
Old Jan 2, 2009 | 08:21 PM
srmofo's Avatar
Default fuel filters?
What fuel filters are you guys using? I've just got a stock one on there now, but Im getting ready to install some fancy steel braided fuel line and I am thinking of going aftermarket with the fuel filter, Im not really concerned with flowing more fuel, I just dont want one that is going to start leaking in 6 months.....opinions and flames welcome
Old Jan 2, 2009 | 08:50 PM
EG BEAST's Avatar
Default Re: fuel filters?
im running the aeromotive one
Old Jan 3, 2009 | 10:24 AM
boostedcivicsir's Avatar
Mr. Badwrench
made 540whp on a stock filter.
using weldon filters now.
Old Jan 3, 2009 | 11:17 AM
nonvtecallmotor's Avatar
Aeromotive here.
I ran the stock one up around the 600hp mark.
Old Jan 3, 2009 | 02:15 PM
rota92
Guest
Posts: n/a
Aeromotive and Kinsler make great units.
Aeromotive has a cool new one with a built in shutoff valve which is great for certain situations. However the Kinsler stuff is used on IRL cars which is nice, for both fuel and oil.
Old Jan 3, 2009 | 03:05 PM
turbotypeR@SPEC's Avatar
25 Year Member
I am using two Weldon filters now, but
I used an AEM stock style filter up until I use dthe Weldon pump and it worked great along with a Bosch pump
Old Jan 3, 2009 | 04:49 PM
NAH2B's Avatar
i just researched this topic myself haha
i went w/ the Aeromotive 10 micron filter between the stock pump and injectors.
when i do the entire system i will most likely go w/ the Aeromotive 100 micron between the tank and pump. these 100 micron filters are also available w/ the shutoff valve like stated above.
Old Jan 5, 2009 | 08:09 AM
fukenricen's Avatar
im using the russell fuel filters, so far so good
Old Jan 7, 2009 | 11:11 AM
jroland's Avatar
Aeromotive for me too great filiter
Old Jan 8, 2009 | 11:15 PM
BubsBoostedEG's Avatar
I have oem lines an filter setup on my recent car works fine at 750whp also have ran aeromotive filters, they are very easy to clean and look nice too.
Old Jan 10, 2009 | 06:29 PM
tony413's Avatar
i've used
1. aeromotive
2. fuel labs
3. Kinsler ( i love them )
4. golan
5. im buying a Canton Mecca for my current project. you cant beat canton mecca
Old Jan 10, 2009 | 07:07 PM
srmofo's Avatar
It looks like Bang for the Buck you cant beat that C/M filter $75, reuild seal kit for $12, replacement elements for $12...1 micron with 90 gph flow, plus you can change the in/out boss sizes from 6an to 12an if I ever need to upgrade the fuel system again...those prices are all from pegasus btw
Old Jan 10, 2009 | 08:03 PM
sanman000719's Avatar
I have the aeromotive a1000 fuel system so aeromotive for me as well
Old Jan 10, 2009 | 08:27 PM
Mr. Em1's Avatar
aeromotive is a guarentee, alot of people here use them, most without problems as long as they are installed properly they shudnt fail !!
Old Jan 10, 2009 | 08:31 PM
PBzAllan's Avatar
i am currently running an earls filter works great for me
Old Jan 10, 2009 | 08:41 PM
LurkerS8's Avatar
I'm running the earl's filter as well on my 450whp setup.
Old Jan 10, 2009 | 09:29 PM
redboost10's Avatar
Originally Posted by tony413
i've used
1. aeromotive
2. fuel labs
4. golan
those golan fuel filters are the worst filter i have ever used. yes they are one of the nicest looking pieces, very nice looking on the outside and very simple on the inside. the fuel pressure kept collapsing the spring so the two filters would be butted up against each other causing fuel pressure to drop enormously. i opened it thinking maybe they sent me the carburetor style with a real weak spring so i ended up sending it back to them and they said that is their efi style filter.
now running a weldon filter.
Old Jan 10, 2009 | 09:56 PM
tony413's Avatar
yeah i wont use them anymore either its was one of those things i got for a good price.
i really like the CM, aero, and Kinsler
Old Jan 10, 2009 | 10:05 PM
redboost10's Avatar
they were very compact, thats what caught my eye. do the kinsler filters use a mesh (metal) screen or are they the cellulose filters?
Old Jan 11, 2009 | 04:49 AM
blackeg's Avatar
same here, but 425whp. -6 ive got it inline mounted on my firewall
Old Jan 11, 2009 | 10:48 AM
tony413's Avatar
you can get either one you need
Old Jan 27, 2009 | 06:04 PM
1fastacvw's Avatar
I ordered two filters from kinsler today, scott was very helpful. download thier catalogue, there is a ton of info in it. im going to run eth so both filters are mesh screen.
Old Jan 28, 2009 | 08:39 AM
tony413's Avatar
kinsler makes great products i got a chance to meet a mustang owner running ITBs from kinsler its a wicked set-up
xsi-t
May 30, 2011 05:16 PM
RoadRaceMike
May 10, 2011 12:38 PM
pjr710
Apr 3, 2010 05:59 PM
eg:R
Mar 31, 2010 05:37 PM
dustin
Oct 2, 2001 04:23 PM
