i hate seafoam!!
i used sea foam on my car i put 2oz's through the intake and it foud all my plugs and messed up my distributor coil yeah how does that happen? i put it in through a vacum hose like i was told let it set for 15min cranked it and 30min it cut its self off and due to foud plugs and a bad coil.
has this ever happened to anyone else?
Might have had a lot of crud in your intake manifold or oil the may have been from a leaky valve seal. Probably got washed into the cylinder and got on your plugs. It can happen.
you dont have to change your oil and plugs afterwards at least I never have and have NEVER HAD ANY PROBLEMS I just drive the $hit out of my car afterwards. Your supposed to let it set for 10 - 15 min then go for a hard drive.
you HAVE to change your oil after using seafoam. seafoam dilutes your oil making it worthless since it will not lubricate moving parts. thats why you change your oil after using seafoam
He probably F'ed up the car more than it already was before the seafoam....LoL
you DO NOT have to change your oil if you put it in through the brake booster line. if you put it in the crank case yes. but you should change your plugs after you run it through your brake booster line
I think the proper way is to use 1/3 in the crankcase 1/3 in the brake booster and 1/3 in the gas tank. Run car hard then change oil and plugs. I did that with my civic and it ran a lot smoother after that.
Shouldn't have caused bad coil. Coincidence I guess.
And seriously, NGK V-powers are like $8 for all 4, so who cares. Buy the new plugs and rest knowing you have brand new spark plugs and won't have to replace them for longer.
read this.
some of the smartest people in honda-tech commented on this thread. read it and tell me you dont have to change your oil. even the OP says you have to change your oil even though he put it in the brake booster line
I Have never had any problems what so ever after using seafoam!!!!!!!!!!!!!! I use it in my IM ands IT never in my oil and I have never changed my plugs after running the seafoam I just drive the **** out of the car till the plugs clear up
I'll say it again never problems what so ever after using seafoam in my intake manifold and I have been doing it for over 10 years STUPID
What line did you use to put it in? Did you also do the crankcase and the gas tank?
I did mine this summer with about 100000 miles and had no problems, made it idle a ish ton smoother.
read this ok
https://honda-tech.com/forums/showth...hlight=seafoam
well knowledge people PROVE that seafoam is bad for the engine. EVEN the OP said that you have to change your oil after using seafoam. AND HE HIMSELF PUT IN IN THROUGH THE BOOSTER LINE!!!
seafoam is supposed to clean carbon build up from your engine, intake mani and exhaust mani. but while doing so, it dilutes your oil. read the link to the thread that i posted. they explain there what happens
read this ok
EDIT: okay i think i figured out your stance, nevermind
CRXDaddy78155
11
Feb 19, 2007 01:03 PM
smercer
Feb 9, 2005 10:12 AM
