cold starting problem
Old Jan 27, 2009 | 09:35 AM
SoFreshh's Avatar
Default cold starting problem
hey I know people have prlly asked this by now but I'm havin problems starting my eg coupe and I wanted to know how I could fix it I'm gonna get my battery checked later but what else could be wrong if it checks out fine
Old Jan 27, 2009 | 09:36 AM
Unseen Racer's Avatar
Default Re: cold starting problem
have you used the search button?
since i am almost positive this has already been covered.
EDIT: so what? your car doesnt want to start? or does it have a rough idle when you start it? what seems to be the problem. be more specific and descriptive please
Old Jan 27, 2009 | 09:41 AM
zeplin's Avatar
Hah, I was going to say you always respond with "use the search" and never offer help. However in the time I clicked quote you edited your post.
@OP - if your battery checks out good, try adding some dry gas. That usually helps with cold starts. It's called Iso-Heet at autozone and is like $3 a bottle. You use 1 bottle with every fillup in the winter for better starts.
Old Jan 27, 2009 | 09:50 AM
i do offer help many times. check the thread about this guy wanting to do a auto to manual swap on his del sol.
i said the same thing about searching but then posted a link on a D.I.Y auto to manual conv.
and its true. there are alot of ppl that just make an account and do not read the FAQ, use search or read the guidelines
EDIT: your starter may also be not working properly, your battery may be low. there can be many problems and many suggestions with a vauge discrpition of your problem
Old Jan 27, 2009 | 03:21 PM
SoFreshh's Avatar
my apologies for the vague description I was in the middle of school as for the starter I don't think it's the problem I can hear it tryin to turn over the motor and sometimes I'll hear the exhaust too like it's startin up but it doesn't I'll give the isoheet a try though oh and tea the car does idle rough at first when I get I to start usually I have to jumpnit the car starts up fine when it's warmed up or garages but not when it sits out in the cold here in Iowa for a few hours
dvlsfan30
Oct 21, 2008 05:09 AM
qksl2
12
Mar 13, 2006 03:49 PM
Tee Jay
11
Oct 26, 2005 03:16 PM
mkinpwrat12g's
Aug 24, 2005 05:50 PM
djbrandonr
Jan 14, 2005 07:48 AM
