Suspension & Brakes Theory, alignment, spring rates....
tension wire?
Old Jan 26, 2009 | 04:51 PM
turbo-crx's Avatar
Default tension wire?
what exactly is this? I saw a crx at Ifo in g'ville with it because he had stock struts in the front and back. Where do i buy this and where do i wrap it around?
Old Jan 27, 2009 | 11:23 AM
turbo-crx's Avatar
Default Re: tension wire?
anyone?
Old Jan 27, 2009 | 12:50 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I have no idea what you're talking about. Tension wire?? I don't think there's anything on a car suspension that has any tension wires. I've seen the factory refer to spark plug wires as "high tension cords" but that's about it.
Old Jan 27, 2009 | 01:23 PM
TunerN00b's Avatar
Are we discussing limiting straps? All they do is prevent full suspension extension, to the point of preload if adjusted to do so.
Old Jan 27, 2009 | 03:41 PM
turbo-crx's Avatar
yes that what im talking about. The guy i spoke with said he used "tension wire". Where do you get the limiting straps from, and how do i install them?
Old Jan 27, 2009 | 03:42 PM
Community Builder
I have never seen or heard of such things. Pics plz.
Old Jan 27, 2009 | 04:04 PM
TunerN00b's Avatar
I have only ever heard of limiting straps being used on offroad vehicles, and drag bikes.
Old Jan 27, 2009 | 04:53 PM
turbo-crx's Avatar
i think he had it wrapped around the upper control arm and the lower control arm.
Old Jan 29, 2009 | 04:40 AM
Targa250R's Avatar
be professional
I see them on a lot of offroad vehicles that use a non-coilover shock with a loose coil spring. I would imagine that they're used allow articulation of the suspension without the spring falling out.
I've seen them on some Civic drag cars as well but I'm not sure of the theory behind them. Limit front-end lift/launch squat possibly?
A single strap that connects the upper arm to the lower arm? That would be totally pointless.
Old Jan 29, 2009 | 05:25 AM
kyden's Avatar
the upper and lower control arms move together, so i don't see how it is useful? its not like the knuckle is seperating from the two.
Old Jan 29, 2009 | 05:33 AM
Community Builder
In the case of a Honda, such straps/wires would have to attach between the LCA or some point on the lower part of the shock, up to the top hat area, to limit the amount that the shock can extend. You would not attach them directly to both control arms.
Old Jan 29, 2009 | 11:34 AM
TunerN00b's Avatar
For cases where the suspension can actually move enough to cause driveshaft or axle contact with a hard point, its cheaper and easier to limit droop with a strap than through shortening the shock shaft.
Also, offroad vehicles can have a tendency to "top out" their shocks, which can have a detrimental effect on their lifespan depending on how hard and how often it happens. Again, the strap is a quick and cheap fix.
Old Jan 29, 2009 | 12:42 PM
kyden's Avatar
i know about limiting straps, i was just wondering why one would do it in such a manner that the op stated (between both control arms)
dstah
Engine Management and Tuning
May 2, 2009 10:13 PM
92vteclude
Oct 3, 2005 01:13 PM
silver hatch
Mar 29, 2005 01:52 PM
Stoich EG2
Dec 11, 2004 08:54 PM
daklown
Jun 9, 2004 10:12 PM
