back purging
Old Jan 26, 2009 | 04:35 PM
extream_86's Avatar
Default back purging
does anyone have and good pics of there back purge setups? do you run it strait off your tank?
Old Jan 26, 2009 | 04:40 PM
m R g S r's Avatar
Default Re: back purging
I ran a T after my reg on the tank. Then a 10 foot hose with a needle valve at the end. you only need to open the needle valve a tiny bit and let the gas fill the inside of the pipe you are welding. don't crank it up too high, because it will steal all the gas from the torch.
I use a "quick cap" rubber cap with a hole poked in it and the hose shoved in one end, and stuff some steel wool in the other end to let the gas flow out of the pipe, not out of the area you are welding. i'll go snap a pic of it later
Old Jan 26, 2009 | 04:45 PM
JDM KID 510's Avatar
Setup from weiRtech. (Hope you mind)
Old Jan 26, 2009 | 05:05 PM
GT35R_EF's Avatar
Make mine whatever you want
Don't have a picture, but I just run two tanks, with the backpurging tank being a little bit smaller of course. Kind of self explanatory lol.
Old Jan 26, 2009 | 05:14 PM
weiRtech's Avatar
OG Fabricator
not at all. here is the writeup:
http://www.homemadeturbo.com/forum/i...?topic=76877.0
Old Jan 26, 2009 | 06:43 PM
punkinbeck's Avatar
I just run two tanks, two regulators, about 7 pound purge gas.. Any ghetto design involing duct tape to seal everything off will work just fine and dandy.
Old Jan 26, 2009 | 11:28 PM
ScorpioMk's Avatar
T off the tank to 2 regulators, and an on off valve on the purge side so i can turn it on and off at will. (little blue handle)
and the cap i made out of some dumptube material, the other side i cap with tinfoil.
Old Jan 27, 2009 | 06:19 AM
shortyz21's Avatar
man why do you use threaded connectors/hoses on the purge line. that takes so long. push to connect lines all the way..
Old Jan 27, 2009 | 07:47 AM
silly sohc's Avatar
One of mine...
Old Jan 27, 2009 | 08:04 AM
ToxicFabrication's Avatar
OG Fabricator
damn!^^^ do you machine the caps?
Old Jan 27, 2009 | 08:19 AM
silly sohc's Avatar
yeah ... just lathe a slight taper
Old Jan 27, 2009 | 05:23 PM
OG Fabricator
wish i had a lathe
Old Jan 30, 2009 | 08:58 PM
atutt's Avatar
I don't have any pictures. I use two tanks.
And for my caps I cut a bunch of canuck pucks in different sizes. Drilled two holes in each puck. One large and one small. Purge tank has a regulator as usual. Then a line attached to a tube which is inserted into the canuck puck.
Pretty simple. Plus the puck can take quite a bit of heat.
Old Jan 31, 2009 | 01:22 PM
srmofo's Avatar
so let me ask you guys something....How do you grind down the bevel for your SS pipes. they all look so perfect....do you just have a jig set up on a grinder? or is there a tool that does this for you?
Old Jan 31, 2009 | 02:37 PM
eclypzex's Avatar
most of them come beveled like that on each end.. unless you cut it, then you can re-bevel it with a sander or bench grinder.
v8killaz
Welding / Fabrication
Sep 8, 2014 10:02 PM
RadekSkylark
Sep 20, 2011 03:35 PM
DA_DRE
Honda Motorcycles
Mar 25, 2008 07:13 AM
Baodalazi
12
Mar 24, 2007 07:59 AM
k4ff1n3
Jun 13, 2006 07:51 PM
