Tie rods question?
Old Jan 26, 2009 | 05:32 AM
TonyBlaz's Avatar
Default Tie rods question?
How hard is it to change the tie rods on a 94 civic? I have to replace the driver front so when I change my brakes i'm gonna do this. I'm gonna replace the inner and outer tie rods on the front driver and passenger side. How hard is this to do? I've never done this before.
Tony
Old Jan 26, 2009 | 05:44 AM
sp00ledbseries's Avatar
Default Re: Tie rods question?
outer is not bad at all. spray them down with some good penetrating oil and let them sit for a little bit. ive never done the inner b4 though. i would recomend a alignment after words though.
Old Jan 26, 2009 | 06:02 AM
Juan_Mitosis's Avatar
Alignment is more than recommended, its necessary. Changing tie rod ends throw your alignment off. For inner tie rod ends you can rent a specialized tool at auto zone or other similar auto parts store, to make the job easier.
Old Jan 26, 2009 | 08:34 AM
vanste's Avatar
alignment is 100% necessary if you replace it unless you just dont care. but all should be easy with proper tool...
Edul59
Suspension & Brakes
Nov 11, 2008 08:17 AM
Built B18ABorC
Sep 22, 2004 06:55 PM
Boosted Chemist
Jun 14, 2004 03:19 AM
suspendedHatch
Mar 28, 2004 11:37 AM
Armed Ferret
Feb 3, 2003 07:14 PM
