Hub bearings or not?
Old Aug 7, 2002 | 10:45 AM
Spade's Avatar
Default Hub bearings or not?
Me and a friend seem to think but I would just like a second opinion.
Steering wheel shakes roughly at speed when brakes applied.
Clunking noise when off trottle at about 85-70 mph....not all the time just everynow and then.
Ugly clank when going over speed bumps without brake applied.
Rotors are not warpped.
Hub bearings?
Old Aug 7, 2002 | 10:53 AM
sgT's Avatar
sgT
Default Re: Hub bearings or not? (Spade)
why dont you just jack up the car and check the wheel bearings.
Old Aug 7, 2002 | 10:56 AM
Spade's Avatar
Default Re: Hub bearings or not? (sgT)
No idea how to check honestly....attempt to wabble wheel? If wheel wabbles = wheel bearings?
Old Aug 7, 2002 | 11:05 AM
sgT's Avatar
sgT
Get the tire off the ground and try to move the wheel from 12 and 6 positions.
if there is play then the bearing is going out.
Old Aug 7, 2002 | 11:07 AM
Spade's Avatar
Got it.
Old Aug 7, 2002 | 01:50 PM
fixhondas's Avatar
Check your axle nuts lately?
Old Aug 7, 2002 | 01:54 PM
Spade's Avatar
Default Re: Hub bearings or not? (fixhondas)
Nope. Those are the crush nuts right?
Old Aug 7, 2002 | 01:57 PM
fixhondas's Avatar
Not crush nuts (ouch!) but you stake them.
Old Aug 7, 2002 | 02:00 PM
Spade's Avatar
LoL.....okay. I must look at that as well......I am basically going to tear apart the car tonight until I can figure out what it is....
So far going to inspect....ball joints, bearings and axle nuts.
Old Aug 7, 2002 | 02:54 PM
Chiovnidca's Avatar
Also check your sway bar end linksand your radius rod bushings. Are your rear brake drums out of round?
damnitdog
Sep 4, 2017 05:07 PM
EJ8mike
Mar 13, 2013 06:28 PM
B18c1_turbo
Mar 14, 2008 10:43 AM
Takeoff
Feb 23, 2003 11:11 AM
whatcivic
Jul 24, 2002 09:38 AM
