--->JDM B18C w/ LSD
FOR SALE JDM B18C SIR-G w/ LSD
2,800$ or best offer
Engine Specs:
Engine code: B18C
Displacement: 1797
Output Power(ps/rpm): 180/7600
Connecting rod bearing width: tetra-methyl lead coated crank 17.5 mm
Connecting rod: high chrome cardon steel
Block Height: 270 mm
Transmission Specs:Y80 with Limited Slip Differential
1st:3.230,2nd:1.900,3rd:1.360,4th:1.034,5th:0.787, R:3.000,Final Drive:4.40
Swap Includes:
Complete Engine & Transmission Assembly(pictured)
Clutch kit: Competition Stg3 Pressure Plate, Type R Disc, Type R Flywheel, New Pilot Bearing, New Throw Out Bearing
Starter, Distributor(OBD2), Alternator(OBD2), Fuel Rail, Injectors, Wires, BLOX Intake Manifold, Integra Type R Stainless Steel Header, P2R Intake Manifold Gasket, Shift Linkage(EG or DC),Intermediate Shaft, Left & Right Side Axles 32 mm, Also have 36 mm(jdm spec) Axles
Engine has 250 Compression All Four Cylinders, Guaranteed No Smoke, Engine runs Strong & Healthy, Transmission Shift normal No Grinds, Engine Has New Water Pump, Timing Belt, Valves are also adjusted to factory specs
Contact Information:
786-316-2598 Frank
Engine Specs:
Engine code: B18C
Displacement: 1797
Swap Includes:
786-316-2598 Frank
bought the motor 64,000 Kilometers, drove it for a year or so about 15,000 miles more or less, like a said mileage is not an issue on these motors, aslong as your compression is high an steady all four cylinders, no burning oil, piston rings good valve seals good, motor is healthy guaranteed...hollla at me mannn
