Car running good at idle however..
Old Jan 24, 2009 | 09:15 PM
BKKloppenborg's Avatar
Default Car running good at idle however..
Hey guys, i just put a new Intake Manifold, and 70mm Omni TB on my car today. It starts up fine and great, however when you hit the gas it stumbles and almost dies Almost like choking and recovers. A few things is New Crane Igntion system 6S box with high Coil, and new Dizzy. Car idles Perfectly fine, Only when i hit the gas probelms come up. Please help i have no car right now ):
Old Jan 25, 2009 | 05:47 AM
Bowman62's Avatar
Default Re: Car running good at idle however..
sounds like mabey the tb may be to big for your application
Old Jan 25, 2009 | 07:45 AM
95 integra's Avatar
MAP and TPS sensors hooked up backwards, ignition system installed incorrectly or bad wiring....those are my guesses.
Old Jan 26, 2009 | 06:37 PM
Ignition system is brand new crane cams Ignition box with coil, Sure thats ok, i will check the sensors tomarrow its now dark. I will also check the wiring.
Now it will not go past 3,500 rpms without seurging up and down up and down. Like Rrrr, RRR, rrrr, almost like its a air issue or some sort.
Old Jan 26, 2009 | 10:26 PM
mouab18c1's Avatar
I'm thinking your tb is too big for your setup. Try like a 68. Or maybe get one hella of a tune for it
Old Jan 27, 2009 | 12:56 AM
wunfstgsr's Avatar
Loved
Community Favorite
what i.m are you using? im guessing it could be your tps wired wrong. or a vacume leak.. my sk2 pro series i.m has a nipple on the back end on the right and if it's not pluged the car wont drive right and it idles bad. good luck.
Old Feb 9, 2009 | 09:37 AM
deadstock's Avatar
did u ever find out what it waas i have a similar issue man but now car wont even start ive checked evrything sparks there fuels tehere checked the ecu and cat they are fine. im lost. let me know what u found mabe we havew simlar problems
Old Feb 25, 2009 | 12:45 PM
Yup after many days of being pissed the &*($ off it was the map sensor and TB sensor Switched. XD
Thanks to all who helped.
Know just need to fix my trans from slipping like crazy.. :D
Old Feb 25, 2009 | 01:15 PM
lifesforlivin's Avatar
New User
nice. thats exactly what everyone seems to do when they change out the intake and throttle body. ive personally seen three people with the same problem and thats what fixed it. gl with the car
Old Feb 25, 2009 | 01:25 PM
pmey's Avatar
check your pcv
Old Feb 25, 2009 | 02:23 PM
qazaq's Avatar
i say check if u connected ur iacv... cause that's how the engine behaves with iacv unplugged
supersilverdc2
Jun 2, 2014 05:56 PM
B_Swapped93
Apr 23, 2014 12:36 PM
2ndchirp
Feb 6, 2010 10:57 AM
darkstar1440
Aug 1, 2006 07:58 PM
ogwutang
May 9, 2003 12:11 PM
