00' ex shuts off when gas is let off! PLZ HELP!
alright, thanks for reading first off
i just picked up this 00 ek ex had a bad block. so i took it out and through a new bottom in on. cranked it up and everything is fine while it was cold... When the engine warms up, and you rev it up a little then let off the gas, RPMS will fall and then car will shut off..
I thought it could be Idle control valve related, so i cleaned it out with brake clean and also cleaned the throttle body.. Same issue
I heard it could be related to some sensor that controls the idle, maybe something that attaches to the throttle body... ANY INFO WOULD BE GREATLY APPRECIATED
Thanks for the help
Thanks for the help
ekowner13
May 12, 2011 02:06 PM
J.Nguyen2
Nov 24, 2005 11:32 PM
