OIL PAN modification!!!
the hole isn't really kit specific. just as long as it is above the oil line and in a position so that when the return line is ran it would allow a free flow of oil from the turbo to the oil pan.
the size of the hole should be any size that accomodates the inlet/oil line fitting
what kind of fitting do they give you for the oil pan? weld or weldless?
also, i'd suggest a weldless setup. i never liked welded setups because they tend to leak. if you really want to go with the weldless setup then let me know and I'll list all the parts you need and what you need to do. think about that option man.....it turns out really clean and i've never experienced a leak.
toolowsol
Feb 9, 2006 01:52 PM
