Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Odyssey error code 0172, Please help
Old Jan 24, 2009 | 12:17 PM
gmmm's Avatar
New User
Default Odyssey error code 0172, Please help
Odyssey error code 0172, system too rich. change O2 sensor, spark plug, PCV value, clean air filter but no help. Any suggestion? Please help!
Old Jan 24, 2009 | 08:03 PM
redej878's Avatar
Default Re: Odyssey error code 0172, Please help
check fuel pressure regulator?
Old Jan 25, 2009 | 11:59 AM
gmmm's Avatar
New User
the fuel regulator is expensive. is that common to fault and how to check? thank you for your help!
Old Feb 12, 2009 | 11:28 AM
NDNV's Avatar
Primary O2 Sensor, EVAP Canister Purge Valve, injectors?
Old Feb 12, 2009 | 01:33 PM
Evs-One's Avatar
Solbros Owns Me
Check valve lash too. See what map sensor voltage is at idle
Old Feb 13, 2009 | 05:23 AM
Ross 2.0's Avatar
In a Junkyard near you.
What brand O2 sensor did you use and which one did you replace?
Old Feb 15, 2009 | 10:02 AM
junbb1's Avatar
replace the Egr valve and clean the port. if it has less than 100k then the dealer will good will it and the repair should be free. This is where I would start without looking at the car
Old Feb 17, 2009 | 09:56 AM
Evs-One's Avatar
Solbros Owns Me
A clogged EGR port causes a too lean condition, and if anything besides a P0401, would throw a P0171.
Old Feb 17, 2009 | 04:11 PM
junbb1's Avatar
I did not say the port was clogged. The valve is opening at times it shouldnt, putting un-needed exhaust gas back into the engine when it shouldnt. or the lift on the egr valve cold be too great. And this will absolutely cause a 172 rich code. more exhaust gas with not enough air will cause this.
Cleaning the port is just smart to do, and it should at least be checked.
Now one thing i would like to know is where Grmmm if from. We have really bad fuel here in the southeast and faulty egr valves and clogged ports are an everyday occurance.. I noticed you were from the west coast where the fuel is much much better and egr problems are from what I understand few and far between, correct me if im wrong. I get this info from the honda techline guys.
But i bet if the data list is observed the egr valve lift volts are going all over the place.
Old Feb 18, 2009 | 09:24 AM
Evs-One's Avatar
Solbros Owns Me
We definitely have/had our share of EGR issues over here as well. Soccer moms need to open up the throttle a bit and clean out the soft carbons
Most guys at techline are a bunch of weirdos anyways
Old Feb 18, 2009 | 04:49 PM
gmmm's Avatar
New User
I give up and let the garage people to handle that. They clean the egr as the people suggest. after that the situation is worse. van sent back to them to check and still didn't know what to do. More error jump up show misfire on 5, 6 cylinders and a lot of thing I forget.
the van had been service by dealer for egr clogged 2 years before and since I just pass one month even still under 60000 miles. They charged me $300 to modify the egr as manufacture suggest. van is 1999 which they extend the warrenty for 8 Years or/and 80000 miles.
Old Feb 18, 2009 | 06:24 PM
Ross 2.0's Avatar
Old Feb 25, 2009 | 05:51 PM
gmmm's Avatar
New User
finally, change egr value cost $150 and problem solved
aemintgsr
Jul 27, 2011 01:19 AM
dlewis2583
Dec 22, 2010 05:12 PM
BEATurBOYS
Sep 18, 2009 05:25 PM
92_EGhatch
12
Jul 22, 2008 11:33 PM
Primetime2628
Jul 17, 2004 05:10 AM
