code 43 help
code 43 help
man i got a code 43 it is the fuel supply system can anyone tell me wat to do because when i drive the car under 60mph the check light is not on but when i passed 60mph on the freeway the check light comes on but when i turn off the car the check light is off. the car is running fine though, all i did was i change the fuel regulator that i got it from the wrecking yard and also changed the fuel filter brand new. So can anyone tell me wats wrong with it? or have anyone had this problem b-4?
Re: code 43 help (longshot)
this exact thing happened to me about a month ago..replace your O2 sensor. I picked one up at Napa for 70 bucks, took about 20 minutes to replace.
Former Moderator
Re: code 43 help (92_EGhatch)
Buy ONLY NTK or Denso 02 sensor though!!! All others are garbage.
Besides o2 sensor the diagnostic flow chart for code 43 is a nightmare - one of the hardest codes to diagnose on an OBD1 car. Just pray to god the o2 sensor fixes it.
:thumbup;
:thumbup;
Former Moderator
Re: code 43 help (wvudelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wvudelsol »</TD></TR><TR><TD CLASS="quote">i'm running a bosch sensor, it works just fine..</TD></TR></TABLE>
...for now.
I've been working at the same Honda/Acura only shop for 8+ years now, and I can't tell you guys how many cars come in flashing o2 codes/fuel supply codes and low and behold a less-than-year-old Bosch o2 sensor has already been installed!
I'm glad yours is working out for you, but again I trust Japanese-made OE NTK/Denso parts over German Bosch crap. I've also seen a lot of cars come in running like crap only to find recently installed Bosch Platinum +4 or equivalent crap spark plugs in the place of NGK/Denso originals.
...for now.
well i havent buy a o2 sensor yet i tried cleaning it but doesn't work so now im stuck need help bad. Even if i buy a new one im not sure if it'll work. think so guys?
hey guys my car is a vx but i put a dx motor in it and also i used the vx engine harness and cx/vx stock header so if i was to get a new 02 sensor which one should i get vx O2 senor or Dx? But my engine harness is the vx harness.
Re: code 43 help (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Buy ONLY NTK or Denso 02 sensor though!!! All others are garbage.
:thumbup;</TD></TR></TABLE>
B18C5-EH2 is exactly right. I've been through this one before. I tried everything, then amazingly, somehow, the CEL went away after the engine was swapped into a different hatch. Go figure. G/L.
civic_boi
03-28-2004 03:06 PM
