About to change my oil pan gasket...
Old Aug 7, 2002 | 08:36 AM
FUP23's Avatar
New User
Default About to change my oil pan gasket...
You guys done this before ? Pretty easy or what ? Tips or tricks on it ? Thanks guys
Old Aug 7, 2002 | 08:38 AM
zcivic91's Avatar
Default Re: About to change my oil pan gasket... (Devin17)
its might not come off when u take the bolts off. so a mallet and a scrwwdriver will help.
make sure u toqure back to 15ftlbs
Old Aug 7, 2002 | 09:21 AM
CWBETB's Avatar
Also make sure you remove the small washers that get stuck on the threads when you take the pan off. I had a headache with mine because I ddint see the small washers from the old gasket still on the engine.
[Modified by CWBETB, 6:22 PM 8/7/2002]
Old Aug 7, 2002 | 09:36 AM
Hondasaurs's Avatar
Default Re: About to change my oil pan gasket... (CWBETB)
I just replaced this gasket 2 days ago. Put the gasket on the bottom of the engine block 1st. Then put the oil pan on. If you put the gasket on the oil pan 1st you will struggle trying to get the oil pan around the flywheel and your gasket will not seat properly.
Old Aug 7, 2002 | 09:37 AM
FUP23's Avatar
New User
Ok thanks guys ..Im gonna start with it ..as much as i dont want to!!
Old Aug 7, 2002 | 09:40 AM
Hondasaurs's Avatar
Just make sure the engine is not hot. You don't want to get burned by hot oil. Also there is a small plate the has to be removed form the flywheel side befor you start to remove the oil pan. I believe it has 2 15mm bolts on it. All of the rest should be 10mm.
Old Aug 7, 2002 | 10:51 AM
keithv's Avatar
Default Re: About to change my oil pan gasket... (ZC_CRX)
work your way from the inside out in a criss-cross pattern when tightening up the oil pan. i had mine leak on me b/c i didn't tighten it properly.
i also tighten it up in like 3 stages to make sure it has an even seal.
Old Aug 7, 2002 | 01:16 PM
Timmah!!'s Avatar
Default Re: About to change my oil pan gasket... (breaka_1_9)
Safest way to go
Old Aug 7, 2002 | 01:36 PM
FUP23's Avatar
New User
Default Re: About to change my oil pan gasket... (azroth)
It went smoothly ..thanks alot
Old Mar 24, 2003 | 07:39 AM
keithv's Avatar
Also make sure you remove the small washers that get stuck on the threads when you take the pan off. I had a headache with mine because I ddint see the small washers from the old gasket still on the engine. <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emsad.gif" BORDER="0">
so do you not use the small washers from the old gasket? the reason i ask is that the new gasket i got didn't have the small washers in it...
Old Mar 25, 2003 | 06:37 AM
sporkcrx's Avatar
I've taken my oil pan and friends off and on many times...and I've never even SEEN a washer. So therefore I think you're talking crazy talk.
Old Mar 25, 2003 | 06:55 AM
Cory man's Avatar
Default Re: About to change my oil pan gasket... (sporkcrx)
the small washers are actually inside the gasket. They fit around each bolt hole so that when the gasket is torqued it doesnt smash out from the tightening of that bolt. One other thing is to remember to Hondabond the corners of the gasket. Ive done a few pan gaskets and they are much fun.
Old Mar 25, 2003 | 07:01 AM
keithv's Avatar
Default Re: About to change my oil pan gasket... (Cory man)
ok thanks for the help. i re-used the old ones and the gsket just didn't sit right and now i know why.
and yes hondabonda is a must for the gasket.
thanks!
Yuta
Nov 6, 2015 06:06 AM
Freshdot
May 18, 2010 06:52 AM
StreetRacinThug
Dec 21, 2006 08:44 AM
ringgold
18
Sep 20, 2004 04:28 AM
andlude
May 12, 2003 05:57 PM
