98 gsr gauge cluster replacement.
Ive looked everywhere and cant find a write up on howto take out the whole cluster. My speedo died in the one in the car and i got one from ebay to replace it. Do i just need to take out the 2 screws on the top of the part that goes around the cluster, pop it out then i will be able to get to the rest of the screws to hold the cluster into the dash? I am trying to figure this out before i go and jump into it. I am hoping the black trim is all i need to take out to get to the cluster without taking the rest of the dash apart.
i just did the swap, the thing is the cluster came from a 95 and mine is a 98. I get a ABS light which i didnt have before and my fuel gauge does'nt work either. Any tricks to get around this? The speedo does work which i needed, should i just swap the speedo from the new cluster to the old one if there are no ways around the abs light (figure i could just pull the bulb) and fuel gauge issue?
SC2.2CL
Mar 29, 2006 11:03 AM
chinkyEyez
11
May 21, 2004 01:51 PM
