[FAQ] How To Install An Integra Type-R Cluster Into Your Non-ITR Integra (GSR, LS, etc...)
Old Oct 28, 2008 | 05:11 PM
  #51
hmoobhero's Avatar
Default Re: (jdmdc2boi12)
so if my jdm itr cluster doesnt lite up...that means theres no bulb or wat???
Old Oct 28, 2008 | 06:28 PM
  #52
t i cl u s's Avatar
So my friend has an JDM ITR Gauge Cluster in his LS and I wanna snag it from him since his car is done. But anyways, he said the miles never started to add up, or like it stopped. Do you know what might be the problem?
Old Nov 11, 2008 | 10:36 PM
  #53
mouab18c1's Avatar
Default Re: (t i cl u s)
Old Dec 8, 2008 | 09:55 AM
  #54
Tooch's Avatar
Originally Posted by BlueIntegraBoy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DiMpL3s &raquo;</TD></TR><TR><TD CLASS="quote">why would u want to change out all the cut outs....
owell nice write up...</TD></TR></TABLE>
Because the location of a couple of icons changed position between 94-97 and 98-01.
So If I have a 94 guage plugs they will work with a JDM ITR cluster? Will I need to do this swap to get this to work? I want to get this taken care of since I am swapping this dash into my civic hatch.
Old Dec 8, 2008 | 10:21 AM
  #55
BlueIntegraBoy's Avatar
The plugs will physically fit, but the wire pin locations might be off. In this case, follow these wiring diagrams.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-97-98-01-integra-cluster-into-92-95-96-00-civic-wiring-diagrams-1053318/
Old Dec 8, 2008 | 11:22 AM
  #56
teg_dc2's Avatar
so you need two gauge clusters to make this work?
Old Dec 8, 2008 | 01:25 PM
  #57
Not necessarily. Two gauge clusters (your original and the one you will put in) allows your new cluster to work flawlessly.
Old Dec 8, 2008 | 05:13 PM
  #58
teg_dc2's Avatar
so im planning to get a 2001 ukdm type r cluster and i have a 2001 gsr will it work okay if i do this and the fuel and everything else will work okay??
Old Feb 1, 2009 | 07:23 AM
  #59
_oemek_'s Avatar
Default Re: [FAQ] How To Install An Integra Type-R Cluster Into Your Non-ITR Integra (GSR, LS
I have a 97 RS. and I just got a 98+ JDM cluster. Will this work if I just follow your directions, or will I have to re-pin any wires in the harness like the 94 or 95.
Old Feb 1, 2009 | 10:41 AM
  #60
Follow the directions and you won't need to repin the wires.
Old Feb 1, 2009 | 11:38 PM
  #61
_oemek_'s Avatar
thanks dude. this is very imformative. im glad I ran into this post. and someone took the time to explain it to us.
Old Feb 11, 2009 | 02:35 PM
  #62
alteclansing's Avatar
I have a 2001 jdm type r cluster but the bulbs are burned out, will my bulbs in my 98 cluster fit and will they be the same colour.. Im pretty sure they will but want to make sure
Old Feb 11, 2009 | 05:43 PM
  #63
They will fit and work. Light will be amber due to the gauge face of the ITR cluster.
Old Jan 22, 2010 | 09:42 PM
  #64
moosta936's Avatar
im having problems with the tach not going past 50 mph. any ideas? just installed n havent done the swap yet with my ls cluster...
Old Jan 23, 2010 | 02:10 PM
  #65
moosta936's Avatar
ok....did the complete gauge swap from the itr cluster into the ls cluster i had, everything works fine like my fuel gauge works now that wasnt before but i still have the tach not going past 50 mph. is my guage broken? or is it circuit board, circuits, wiring or something of that nature?
Old Jun 28, 2010 | 07:49 AM
  #66
KTsCRX's Avatar
thanks for this link BlueIntegraBoy now it dosnt matter I will just find one now and pick up.
Old Jan 11, 2011 | 04:55 PM
  #67
KidCuda's Avatar
followed steps for UKDM ITR cluster into 2000 GSR and no luck
Old Apr 6, 2011 | 11:05 PM
  #68
vtecdan's Avatar
im also trying to get my gas gauge working i have a 96 gsr and a ukdm itr cluster can anyone hlep guide me?
Old Apr 7, 2011 | 05:37 AM
  #69
duscar's Avatar
So do you have to do this if you swap in a USDM ITR cluster into a USDM GSR? I wouldn't think so but I don't know. What about a 98 USDM ITR cluster into a 99 GSR?
Old Apr 7, 2011 | 05:41 AM
  #70
98 ITR cluster into 99 GSR wouldn't need any modification.
Old Nov 7, 2011 | 05:32 PM
  #71
Nuubz's Avatar
great write up!
i've got a 98+ ITR going into a '95 GSR, will it need re-pinning?
much appreciated
Old Nov 29, 2011 | 06:59 PM
  #72
EKool's Avatar
I've never swapped any of my clusters before.. now if you put km/h faces on a usdm cluster will the meter still move the needle as if it had mph faces.. u kno what I mean? Will it read your speed in km's properly.. regardless I'm still gonna doit hahaa good lookin though
Old Dec 2, 2011 | 07:52 PM
  #73
EKool's Avatar
Well im a idiot lol.. but i followed your steps.. put in a 94 ls cluster an it works perfect... Thanks alot!
Old Dec 6, 2011 | 05:16 AM
  #74
astroboy84's Avatar
nice!
Old Dec 6, 2011 | 04:31 PM
  #75
RookieCivic's Avatar
great wright up!!!!!!!!!!!!!!!
