Aftermarket USDM ITR headers: Direct Bolt On for LS?
Old Aug 7, 2002 | 07:25 AM
98R-1144's Avatar
Default Aftermarket USDM ITR headers: Direct Bolt On for LS?
Got a used USDM DC 4-1 for sale off my ITR... was wondering if it was a direct bolt on for LS... or pretty much the header will only bolt on for ITRs.
Old Aug 7, 2002 | 07:33 AM
Spade's Avatar
Default Re: Aftermarket USDM ITR headers: Direct Bolt On for LS? (98R-1144)
ANy B series header will bolt onto a B series engine. The exhaust ports are the same.
It is just the fitment to the chasis. I.E. A b-series in a hatch will have to modify something to get it to fit.....header or cat-back.
Old Aug 7, 2002 | 07:43 AM
98R-1144's Avatar
Default Re: Aftermarket USDM ITR headers: Direct Bolt On for LS? (Spade)
so all the Bseries headers will be a direct bolt on to the stock CAT... be it on an LS/GSR/ITR?
Old Aug 7, 2002 | 07:45 AM
Spade's Avatar
See that is the thing, what stock cat? The ITR's or the LS's?
Are you trying to get a ITR header on an LS with the LS cat&cat-back? (Might have fitting issues)
Or are you pulling the entire ITR exhaust and putting it onto the LS (Yes)
Old Aug 7, 2002 | 08:38 AM
Kataku2K3's Avatar
They are both the exact same on each end.... My friend has a GSR hatch that had a 4-1 DC header on it for a GSR. It cracked so we put a stock LS header on it and had to have the cat modified. Then i gave him my US ITR header and it bolted right up, so you should have any problems.
Old Aug 7, 2002 | 09:57 AM
98R-1144's Avatar
Default Re: Aftermarket USDM ITR headers: Direct Bolt On for LS? (JDMspecEG6)
so the ITR header bolt directly onto an LS with a stock LS without any modifications to the cat (shortening/lengthening)?
Old Aug 7, 2002 | 09:58 AM
sgT's Avatar
sgT
ITR, LS and 00-01 GSR header and exhaust are interchangable
san_diego_DC
Jul 14, 2008 03:50 PM
silentdeath12886
Aug 28, 2006 04:07 PM
Johnny62
Sep 27, 2002 06:39 PM
ILOVEGIRLS
Sep 17, 2002 11:57 AM
mrazian
Mar 25, 2002 04:46 PM
