Squeak from DS front (I've searched)
Old Jan 23, 2009 | 09:05 AM
SH4DY's Avatar
Icon2 Squeak from DS front (I've searched)
Quick run-down: Happened for the first time shortly (20 miles) after going to a 1/2" wider tire. Couldn't find anything and it went away after a while. Came back a few weeks later and it's been intermittent since then (seems to do it more in colder weather?). The louder the noise the harder the steering becomes.
Description of Noise: Squeaking noise from drivers side front occurring during the 1st half turn of the steering wheel in either direction, during stopping and leaving from a stop. Only happens when full weight of the car is on the wheel.
Steps I've taken: Initially I thought it sounded like the spring was spinning on the strut perch, so I spun the spring back from the stop some and the noise went away for a while. Noise came back, spring had not moved.
I've checked the brake hardware several times and nothing seems to be touching.
The hubs have new ball-joints less than 6 months old.
The tie-rod ends are less than 2 months old.
I replaced the springs this week and installed Ground Control coilovers.
I've tried wd-40ing the hell out of everything
Car does not have power-steering (00 CX)
Help?
Old Jan 26, 2009 | 03:08 AM
SH4DY's Avatar
Default Re: Squeak from DS front (I've searched)
I think I'm going to try and replace the upper ball-joints with an adjustable camber kit. Hopefully that will be the ticket...
OblivionLord
17
Dec 27, 2009 07:21 AM
poisonko
Jan 15, 2006 12:30 PM
hi mom
Oct 13, 2004 06:32 PM
Supra
May 11, 2004 01:48 AM
redteg1
Sep 26, 2001 09:09 AM
