What shift linkage in a swap
Old Jan 23, 2009 | 09:04 AM
civics4lyfe's Avatar
Default What shift linkage in a swap
B16a with a hydro tranny from a 92-95 SiR into a 94 dx hatchback.
Can I use the 92-95 SiR linkage that they (hmotorsonline) send with it? If not, what shift linkages will work? I was told a 94-01 teg linkage. Will a linkage from any 94-01 teg work? Should i spend the money on a new one, or look for a used linkage?
Thanks
Old Jan 23, 2009 | 09:53 AM
Default Re: What shift linkage in a swap
Old Jan 23, 2009 | 10:30 AM
mpls's Avatar
yea the stock from the b16 should work just fune
Old Jan 23, 2009 | 11:04 AM
davefromPA's Avatar
answered already on your other thread but if you have the sir linkage it will work. for your short shifter question, you can use either single or dual bend.
Old Jan 23, 2009 | 03:29 PM
SiYouLater's Avatar
B-series linkage will work for B-series swaps.
Old Jan 23, 2009 | 03:44 PM
BryanM.'s Avatar
Resident Gearhead
Except Del Sol VTEC linkage which only works for Del Sols.
Old Jan 23, 2009 | 04:02 PM
**** so this is del sol motor or no? it just says SiR-II, doesnt say what it was pulled from or what OBD it is
http://hmotorsonline.com/shop/sc2000...age&item=30005
Old Jan 23, 2009 | 04:03 PM
Paul-R's Avatar
any b series link will work .
Old Jan 23, 2009 | 04:06 PM
dumafit's Avatar
just stick with any 94-01 integra shift linkage and you'll be fine
Old Jan 23, 2009 | 04:10 PM
i know the 94-01 linkage will fit, but i dont want to buy one if the SiR-II linkage theyre sending me is doable
Old Jan 23, 2009 | 04:46 PM
Old Jan 23, 2009 | 05:33 PM
iamthefollower's Avatar
MCVtec already said, all will work EXCEPT the del sol VTEC linkages..
If it is an Sir II motor, more than likely its from a civic and not a del sol.. you should be fine....
Old Jan 24, 2009 | 12:08 AM
SiYouLater's Avatar
That motor is a direct swap, so yes, everything including the linkage will fit.
BRG+Honda=JDM
Jun 22, 2007 11:25 PM
dobbs1027
Sep 9, 2004 05:55 AM
ID_ten_T
Jan 8, 2004 06:14 PM
specie
Nov 8, 2002 08:14 AM
opusONE
Feb 1, 2002 04:10 AM
