1st time engine swap, and i got two codes help plz
Old Jan 22, 2009 | 05:46 PM
xwhitchx's Avatar
Icon3 1st time engine swap, and i got two codes help plz
ok, i'm getting code 10 and 14, i know what they are, its a 95 honda civic, its from the intake manifold sensors.... my question is does anyone know how the 3 plugs go in? cuz i dont think there in the right spots. i have tried every way to put then together... but no dice(it didnt work) yeah i need help asap i need to go to work!!
Old Jan 22, 2009 | 05:50 PM
h224thgensedan's Avatar
Default Re: 1st time engine swap, and i got two codes help plz
Iacv has a grn/wht wire and the IAT has a Red/Yel
Old Jan 22, 2009 | 05:56 PM
xwhitchx's Avatar
thx i love you
Old Jan 22, 2009 | 06:00 PM
lol work for you
Old Jan 22, 2009 | 06:07 PM
xwhitchx's Avatar
no actually, do u have any pics?? or anything
Old Jan 22, 2009 | 06:19 PM
Did you reset your computer
Old Jan 22, 2009 | 06:26 PM
xwhitchx's Avatar
yep, ok this is what wire i got:
plug1: wire1= green/ white
wire2=red/yellow
Plug2: wire1=yellow/black
wire2=red
Plug3:wire1=yellow/red
wire2=black
i hope this helps you help me
Old Jan 22, 2009 | 06:38 PM
krucial7integra's Avatar
do you have them plugged in backwards? I believe the iat and iacv have the same connector.
Old Jan 22, 2009 | 06:50 PM
xwhitchx's Avatar
they do but that thing is there are 3 plugs back here and i dont know were they go and there all fit the same
Old Jan 22, 2009 | 07:32 PM
jr_deleon's Avatar
Cant tell which engine you swapped in, but that red/black yellow plug is for you emissions control purge (has a number 7 vacuum hose going to your charcoal canister). Where that plugs into is the little black hat looking thing on the rear drivers side of the intake manifold.
The IAT plug (green/white and yellow/red wires) plugs into the sensor held to the rear of the manifold by two philips screws below that black sensor (its white in color) that wouldnt throw a code. Some of our civics have a white colored plug for the IAT just to let you know
the last plug goes to your IACV (cant miss that its held at the back of the manifold with 2 12mm head bolts and its closest to the TB)
that should do it. That also applies to the B series swaps in case you decide to do that in the future (or if you thats what you got)
Old Jan 22, 2009 | 09:42 PM
xwhitchx's Avatar
thx for ur help and its not a b its a d15
Old Jan 23, 2009 | 05:29 AM
jr_deleon's Avatar
Thats why i said its the same for either motor. its easy for either series of motor.
Since its a D motor everything is exactly where it was with the original motor so plug away!
Atomic_EF9
May 14, 2011 04:00 PM
fast2camciv
Aug 7, 2007 12:35 PM
LaXcAt
Mar 23, 2006 10:42 AM
LuderX
Jan 13, 2003 05:49 PM
