what is code
Old Jan 22, 2009 | 04:50 PM
90 ef's Avatar
Default what is code
10
Old Jan 22, 2009 | 04:52 PM
D16SiHatch's Avatar
Default Re: what is code
short flash indicates 1, long flash indicates 10
Diagnostic Trouble Code (DTC) System Indicated
0 Engine Control Module (ECM)
1 Heated Oxygen Sensor (HO2S)
3 Manifold Absolute Pressure (MAP Sensor)
4 Crankshaft Position (CKP Sensor)
6 Engine Coolant Temperature (ECT Sensor)
7 Throttle Position (TP Sensor)
8 Top Dead Center Position (TDC Sensor)
9 No. 1 Cylinder Position (CYP Sensor)
10 Intake Air Temperature (IAT Sensor)
13 Barometric Pressure (BARO Sensor)
14 Idle Air Control (IAC Valve)
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor (VSS)
20 Electrical Load Detector (ELD)
21 Variable Valve Timing & Valve Lift Electronic Control Solenoid Valve (VTEC Solenoid Valve)
22 Variable Valve Timing & Valve Lift Electronic Control Pressure Switch (VTEC Pressure Switch)
23 Knock Sensor (KS)
30 A/T FI Signal A
31 A/T FI Signal B
41 Heated Oxygen Sensor (HO2S) Heater
43 Fuel Supply System
Old Jan 22, 2009 | 05:03 PM
90 ef's Avatar
thats what i thought it was the air temp thing. i changed it with a new one and the check engine light still comes on and the ecu still flashes one long one so what the heck
Old Jan 22, 2009 | 05:04 PM
dacrxguy's Avatar
have you tried to see if the circuit is at fault???
Old Jan 22, 2009 | 05:18 PM
90 ef's Avatar
how can you tell if the circuit is at fault
Old Jan 22, 2009 | 05:44 PM
jlicrx's Avatar
what ECU do you have? - OBD0 D-series ECUs don't have long and short flashes, only short
Old Jan 22, 2009 | 05:47 PM
90 ef's Avatar
i dont know its a stock 90 civic dx hatch d15 from a crx. is there a difference between a d15 hatch and crx?
Old Jan 22, 2009 | 05:49 PM
jlicrx's Avatar
stock ECU flashing once is O2 sensor
Old Jan 22, 2009 | 05:58 PM
90 ef's Avatar
i replaced that to but i will check that out later thanks
Old Jan 22, 2009 | 06:30 PM
90 ef's Avatar
can you scan page 11-36
Old Jan 22, 2009 | 07:50 PM
90blackcrx's Avatar
Download the whole manual
www.hondaswap.com
Old Jan 23, 2009 | 06:06 AM
jlicrx's Avatar
Old Jan 23, 2009 | 03:43 PM
90 ef's Avatar
which one is the hazard fuse?
Old Jan 24, 2009 | 07:48 AM
jlicrx's Avatar
hazard/ECU fuse is the top fuse in the row of 5 closest to firewall in the underhood main fuse box
98tegLSvtec
Jul 31, 2011 01:33 PM
stoneys88hatch
Engine Management and Tuning
Oct 20, 2010 11:59 AM
CustomX113
11
Sep 1, 2006 01:27 PM
civic889802
Dec 30, 2005 01:04 PM
xxthabest1xx
Mar 15, 2003 06:06 PM
