ignition timing questions
Old Aug 6, 2002 | 11:19 PM
_Endless_'s Avatar
Default ignition timing questions
i know there's an effect if you retard or advance your ignition timing. i like to know if you can tell if the ignition is retard or advance just by the way the engine cranks up? like if your ignition is retard will be a typical cranking behaviour and vice versa with the ignition in advance. thanks
Old Aug 7, 2002 | 02:25 AM
kinesistech's Avatar
Default Re: ignition timing questions (_Endless_)
some ignitions systems have a start retard. Its easier to start a high compression engine if the ignition timing is retarded.
Old Aug 7, 2002 | 09:19 AM
Kataku2K3's Avatar
Default Re: ignition timing questions (kinesistech)
I don't know if you can tell right from when the motor starts up, but retarding will feel laggy when you rev it up on a normal motor and advance will feel more like it just wants to go.
Old Aug 7, 2002 | 10:49 AM
IlikeTODA's Avatar
I believe MSD makes one of these if someone needs one.
Thanks, J
RACEPAK
Engine Management and Tuning
Oct 30, 2014 06:13 PM
xtal
Oct 20, 2002 01:39 PM
evo
Feb 21, 2002 05:11 PM
