cel in upper rpms goes away when i restart car
I just got a 94 si. When i go over around 6k i throw a cel. The only problem is that it goes away when i restart the car. I definitly lose power up top once the code is thrown. How can i check for this code? Also any suggestions i am thinking it is part of the vtec solenoid just looking for a clearer answer.
have you ever checked the code? it's probably a random misfire as you say it's only happens in high rpm. get a stronger ignition coil if it's really a problem.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
im willing to bet its gonna be code 22... if it is take off ur VTEC soleniod and clean the mesh screen its probably clogged up...happened to a GS-R i was working on with a couple of friends..."professional" mechanic over tightened everything and had metal shavings in the oil causing the screen to get clogged
that is what i was going to do and still am i am just wondering why it will only do this in second and third gear but not first?
