Just GOT MY SWAP TONIGHT :D Couple quick q's tho..
Old Aug 6, 2002 | 09:44 PM
MikeMAN's Avatar
Default Just GOT MY SWAP TONIGHT :D Couple quick q's tho..
hey all, finally got my new b16a2 into my 98ex..and WOW!!! WHAT A DIFF!!!
Couple questions tho:
1. The headlights/crappy indiglo gauges dim slightly under acceleration, and then get a tad brighter when i let up...distributor?? nothing to worry about??
2. I can't sqeal going into 2nd, or 3rd like I could with my D16Y8, bad clutch?
any info is appreciated!
p.s. this thing pulls like a raped ape once u get the R's up there!!!
thanks again,
mike
[Modified by MikeMAN, 6:21 PM 8/8/2002]
Old Aug 6, 2002 | 09:59 PM
SiBirdie's Avatar
Default Re: Just GOT MY SWAP TONIGHT :D Couple quick q's tho.. (MikeMAN)
dont get the gsr ecu because its was design to only run on gsr head. Gsr have 2 butterflies point while b16 head and type r head have one. So you will feel the lag on low rpm until 2nd vtec kicks in. I try it before and it suck major *** and I wouldnt do it if i were u.
lates
Old Aug 6, 2002 | 10:01 PM
MikeMAN's Avatar
Default Re: Just GOT MY SWAP TONIGHT :D Couple quick q's tho.. (SiBirdie)
it wasn't my choice, the guy didn't ask me...he just did it...he said the 99-00 si' harness wouldn't work on my 98 ex...what would be the best ECU to use??
thanks,
mike
Old Aug 6, 2002 | 10:10 PM
Kamin's Avatar
1) your vtec is engaging too early. you need to get a civic SI ecu or hondata then have it tuned.
2)it might be the alternator on the motor
3)sounds like the clutch or your just not used to it yet.
Old Aug 7, 2002 | 05:21 AM
No-Gi's Avatar
2nd Vtec ? What the hell are you talking about boy!
Old Aug 7, 2002 | 06:48 AM
MikeMAN's Avatar
Default Re: Just GOT MY SWAP TONIGHT :D Couple quick q's tho.. (B16aEK)
what should VTEC be engaging at when its a normal SI??
thanks,
mike
Old Aug 7, 2002 | 06:54 AM
Rydaddy's Avatar
5500 rpm i think?
Old Aug 7, 2002 | 06:55 AM
MikeMAN's Avatar
Default Re: Just GOT MY SWAP TONIGHT :D Couple quick q's tho.. (Rydaddy)
okay, thanks.....does this mean since the VTEC is engaging too soon, is it also adding more fuel too soon?
thanks,
mike
BTW: would a fields VTEC controller pretty much take care of this..
thanks again,
mike
Old Aug 7, 2002 | 11:37 AM
MikeMAN's Avatar
anyone else got any input on this?? I really love the added power, and the sound is MUCH more defined than my SOHC....the guy that did my swap even got me a Civic Type R valve cover because the other one was chipped...
it was great!
thanks again,
mike
Old Aug 7, 2002 | 12:52 PM
madtownhonda's Avatar
I'm running a 97 Del Sol vtec in mine. plugs right into the EX harness. You need a 96-97 Del Sol vtec ecu (OBD2 P30). That's your best bet.
Old Aug 7, 2002 | 12:58 PM
slooowDX's Avatar
Default Re: Just GOT MY SWAP TONIGHT :D Couple quick q's tho.. (madtownhonda)
go ahead and get a VTEC controller and bump up the VTEC to bout 5500-5700, it'll feel a lot better
Old Aug 7, 2002 | 08:39 PM
CivicEx95's Avatar
damnit, majority of people have no ******* idea how vtec and the secondaries work on the GSR and it spreads a lot of misinformation. Let me spell it out how it works straight out of the Helms manual.
VTEC engages at 4400rpm
Secondary butterflies open in intake manifold at 5750rpm
Redline is 8100rpm
Old Aug 7, 2002 | 09:48 PM
MikeMAN's Avatar
Default Re: Just GOT MY SWAP TONIGHT :D Couple quick q's tho.. (CivicEx95)
so is fuel cutoff at 8400 then? I thought redline is 8400, at least that is when it cuts out for me..
thanks again,
mike
p.s. so..i have a b16a2, there are no secondary butterflies that open right?
Old Aug 7, 2002 | 09:49 PM
MikeMAN's Avatar
BTW: My AC isn't working either...does it need to be recharged after the swap? or what..
thanks,
mike
Old Aug 8, 2002 | 12:42 AM
boostinb18's Avatar
ok redline does not mean fuel cut off........ fuel cut off=rev limiter...i think its 8400 on a gsr ecu and no you dont have secondaries on your b16, and your A/C shouldnt need recharging.....did they even put it back on your car?? hook it up?
Old Aug 9, 2002 | 02:41 AM
lilxvtecxpwr's Avatar
Default Re: Just GOT MY SWAP TONIGHT :D Couple quick q's tho.. (boostinb18)
i have a b18c1 running on an si ecu....i need a gsr ecu, u need an si ecu... wanna trade? pm me if u are interested.
Old Aug 9, 2002 | 08:10 AM
MikeMAN's Avatar
Default Re: Just GOT MY SWAP TONIGHT :D Couple quick q's tho.. (lilxvtecxpwr)
the Si ECU won't work on my car, the 96-98 OBDII ECU's are different than the 99-00 ones...the engine came with a 99' Si ECU (because it was a 99 Si engine) and he said it wouldn't work..
thanks for the offer tho!!!
mike
Old Aug 9, 2002 | 09:56 PM
MikeMAN's Avatar
anyone else have any input?
thanks,
mike
Old Aug 9, 2002 | 10:21 PM
sparq's Avatar
dimming is the alternator - not getting enough power, yank it and bring it to NAPA or any place that checks alternators its probably bad. If not, double check all your grounds... and if that dont work, give it a swift kick and hope nothing falls off
Old Aug 10, 2002 | 03:57 PM
00CIVICwB18C1's Avatar
thanks,
mike
Unless they took the stock compressor off the motor and left it all hooked up to do the swap (HIGHLY unlikely), they had to unhook both your a/c lines and let all the refrigerant out. So, yes you need to recharge it.
[Modified by 00CIVICwB18C1, 5:58 PM 8/10/2002]
justin11
May 20, 2013 03:40 AM
hECtUbiS
Sep 11, 2004 11:06 AM
B18C-RnVA
Dec 8, 2002 04:38 PM
04accordV6
Sep 10, 2002 07:11 PM
