b18c boostin questions HELP
ok so i swapped my gsr into my ej. the motor is a 97 car 98 and i was wondering until i can afford to build my motot which i plan to built it for 22psi what does everyone think what boost can i run on stock internals with a tune. i mean i would get injectors already got skunk 2 intake mani and megan racing intake and im buying a new fuel pump. anything else i should get for boosting stock internals abd what psi can i run and b safe this is my dd and i can blower her up haha
first i'd get rid of the megan intake, you won't need that if your going turbo. as for 22 lbs. not sure if the bottom end can handle that. i would have to venture and say probably not. i would say around 12 would get you to where you gotta go pretty quick. 22 just wouldn't be practical for a dd.
well i wana boost 22psi in the futre as high boost and run a low boost as a dd. so what kind of turbo size and turbo kit does everyone recomend i get so i can boost 6 psi on stock internals but also in the future be able to run a way higher boost. do u really think 12 psi on stock internals is safe or should i just boost 6
The forced induction forum would be the best place to ask a question about boost.
I tried searching and found this as well:
https://honda-tech.com/forums/showth...als+stock+b18c
In reading other searches 8psi seems to be the max as far as safety goes. Best of luck op!
ok well im gona boost it 5-69 psi and heres the stuff im gona get correct me if u no anything better or sumthing.
im gona buy a full turbo kit what size turbo should i get
new injectors
new fuel pump
tune by one 6 motor sports
and i have stock p72 but i have a vafc iss that gona work
am i missing nething
new injectors
new fuel pump
https://honda-tech.com/forums/forced-induction-49/re-introducing-entire-afi-line-up-introductory-sale-b-d-h-k-turbo-solutions-manifolds-comb-2066725/
I hear good things about AFI...they have a street kit that should get you to 300whp w/good tuning.
Greddy also sells that full kit (injectors, management, etc..)
http://www.inlinefour.com/gredbolturki.html
Even comes w/a carb sticker!!!
I'm not much of an FI person but i hope this helps a little...
