B18C turbo setup not boostin up
Old 10-28-2005, 12:13 PM
JuiCe57's Avatar
Default B18C turbo setup not boostin up
Hi all,
Need some pointers here.. I'm running a B18C wif T04B/T3 and power FC. I can't seem to get anything more than 0.4 bar boost wif wide open throttle. My boost is goes up to 0.4 then jumps rapidly acting like a motor that's running at 8500 wif a rev cut. I've checked all my piping, removed the intercooler, changed the wastegate and have only the turbo thats left to be examined. Has anyone encountered such problems before? I need confirmation that it's my turbo that's gone before I change it. If I'm gonna change my turbo and then realise that it's still not boostin up I be dead broke and still not boostin..
Any kind soul pls help!
Old 10-28-2005, 03:09 PM
Moderator
TheShodan's Avatar
Default Re: B18C turbo setup not boostin up (JuiCe57)
In your Power FC, (Since you're running the boost kit) You need to go to the BOOST menu, and raise the Boost limit up OVER the amount of boost you're trying to run, so that it doesn't fuel cut. That's somewhat common. You can access that area from the commander
Old 10-28-2005, 03:36 PM
B18 CYA's Avatar
no boost wif ur turbo setup?
Old 10-28-2005, 03:55 PM
Moderator
TheShodan's Avatar
Default Re: (B18 CYA)
No. what I'm talking about is the boost option kit that needs to come with his power FC that includes the DENSO solenoid so the POWER FC can see boost. It has to allow the boost cut off to be raised.
Old 10-28-2005, 04:47 PM
B18 CYA's Avatar
ok, and what im talking about is making fun of the original posts grammar
ufakeit
14
09-26-2009 05:51 PM
rice a roni
05-18-2006 07:01 PM
BlownBlackSi
11-07-2005 08:28 PM
SOHC_MShue
06-15-2004 09:52 PM
Quick Reply: B18C turbo setup not boostin up
