Wtf map srnsor
Old Jan 21, 2009 | 01:58 PM
northemt88's Avatar
Default Wtf map srnsor
so i have a 1989 crx with a obd0 LS,i was turbo for a while,it had a missing link and fmu.but this weekend i went back to stock.SO when it came to pluging in the map it would not hold idle and it wont start unless i give it gas.im open to any suggestion.thanks
Old Jan 21, 2009 | 03:17 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Wtf map srnsor
I assume you removed the missg link (probably wouldn't matter if it was sitll on).
Are you running a chipped ECU with a turbo program on it?
Old Jan 21, 2009 | 03:31 PM
Crx Jimmy's Avatar
make sure the missing link is removed but it shouldnt matter at idle, even if he did have a turbo program in the ecu the vacuum portion of the map should be almost stock and it should still idle and run fine. but if it had a missing link and fmu I doubt it had any ecu tuning, did it have larger injectors and the stock ones were swapped back in, try stock injectors . it should run fine if just the turbo and associated hardware was removed, was the base timing messed with check the timing as well
Old Jan 21, 2009 | 04:39 PM
northemt88's Avatar
yeah its all stock.when the map is pluged in to the vacume i got to give it gas to start,then it will die out,when its not pluged it starts right up
chrisfromsrq
Sep 26, 2009 12:20 AM
infamous55016
Sep 2, 2008 12:56 PM
96EKshaved
Sep 4, 2005 01:20 AM
hotimportcrx
Jul 22, 2005 11:44 AM
AngelTeg
May 25, 2005 03:12 PM
